traction issues
Old Apr 7, 2010 | 11:29 PM
SpEcToR's Avatar
traction issues
installed the cusco front a-arms, spc rear camber, toe bolts then had the alignment done...after that i noticed that when i exit 360 from 20, i take the turn at about 80 and if i allow any of the weight back on the front, my traction control kicks on
front specs:
caster: left - 10.2 -> 8.1
right - 9.3 -> 7.6
camber: left - -2.1 -> -2.0
right - -2.1 -> -2.1
toe: left - 0.00 -> 0.03
right - -0.31 -> 0.04
total - -0.31 -> 0.07
rear specs:
camber: left - -2.7 -> -1.7
right - -2.4 -> -1.4
toe: left - -0.47 -> 0.17
right - -0.37 -> 0.18
total - 0.84 -> 0.35
*I have some camber wear on the front with some irregular toe wear. and two different tires in rear (same size though)
...i'm at a loss
Old Apr 7, 2010 | 11:50 PM
r1forever80's Avatar
When you mean weight up front you mean hit the brakes?
Old Apr 8, 2010 | 09:05 AM
SpEcToR's Avatar
right...or if i'm in a lower gear, and i let off the gas, it transfers weight to the front.
Old Apr 8, 2010 | 11:07 AM
brandon1978's Avatar
That is usually a sign of a well balanced car. I know it isn't always possible on the street, but slow down before the turn and keep the rear end planted (accelerate) through the turn. You didn't mention suspension mods. Softening the rear susp will help keep the rear planted. I went from sedan sport springs to 350z revised and have the same issue. I'll probably switch to unrevised at some point.
I have ... different tires in rear (same size though
That's no good. It will get you were you need to go, but I hope you are saving up for a matching rear set.
Old Apr 8, 2010 | 11:09 AM
SpEcToR's Avatar
i bent a rim about a week or so ago, and damaged with sidewall of the tire. they didn't have another one of my tires in the area, so i had to settle...similar tread pattern though.
Old Apr 8, 2010 | 09:04 PM
SpEcToR's Avatar
bump for further insight
Old Apr 9, 2010 | 01:07 PM
SpEcToR's Avatar
no one can see any issues in my specs? want this problem resolved guys...
Old Apr 21, 2010 | 08:53 PM
gotspeed81's Avatar
sounds like the same problem i was havin when i had my camber kit on my car.
G35Rican
Jul 31, 2024 01:37 AM
cmesidewayz
Sep 29, 2015 09:28 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
