If I am cutting my rotors, do I need to change my brake pads?
Old Apr 11, 2010 | 01:16 PM
i3eezenotch's Avatar
Hey guys, I get a sort of pulsation when I brake. I figure I need to get the rotors cut. My pads still have a lot of life though and I was told if I cut the rotors, I should change the pads or th e pads will re-form the unevenness in the rotors and the pulsation will return. Is this true?
Alos, is there any downside to having this pulsation/uneven rotors or can I just keep driving with it? It's not obnoxiously noticeable, but you can definitely tell it's there. Thanks!
Old Apr 11, 2010 | 01:25 PM
G35 2007's Avatar
yes its true on the pads, but our rotors are composite you cant cut composite rotors though. Im not a hundred percent sure though maybe some one else will chime in.
Old Apr 11, 2010 | 02:01 PM
So either way, I should not cut the rotors since I won't be changing my brakes?
Also, if my rotors can't be cut, what do I do to get the pulsation to stop?
Old Apr 11, 2010 | 02:08 PM
bag35's Avatar
if you do cut your rotors you should definitely change your brake pads. the problem is that if your brake pads are uneven they will groove into your fresh cut rotors and mess em up. u always wanna take care of both at the same time or else you are pretty much wasing ur time and money.
Old Apr 11, 2010 | 02:11 PM
bah, oh well. I just changed my fronts like 2 months ago too... should have done it then. I guess I have like 30k miles to go before I can fix this pulsation then :P
Old Apr 11, 2010 | 02:15 PM
antknee's Avatar
well it might be a lil shaking/pulsating for you but for the engine and everything else in the car its shaking pretty hard... so and if u got warped rotors most of the time itll shave the brakepads easily so u ight be better off fixin both right now.. i have the same problem and believe me the pulsating just gets worse and you dont want a lot of shaking in your car while driving/braking.. just shaking when its parked if you get my drift..
Old Apr 11, 2010 | 02:18 PM
Well it's really not THAT bad right now. I wonder if they can resurface the brakes too without losing much at all off the pad...
Old Apr 11, 2010 | 02:19 PM
I also wonder if they are supposed to check the surface of the rotor when they change the brakes...maybe I can go back to that place that changed my brakes like 2 months ago and request that they replace them with new pads because of that...also they have been squealing anyway since I got them.
Old Apr 11, 2010 | 02:22 PM
antknee's Avatar
there you go the worse is theyll say no and you have to buy new pads.. i suggest hawk performance pads btw.
Old Apr 11, 2010 | 08:02 PM
I guess I'll try it...but if they say no, I probably won't be able to afford to change it atm...
Old Apr 11, 2010 | 09:08 PM
Dudefish's Avatar
...ummm NO
our rotors are not composite, they are most likely plain old ductile iron and most definitely can be machined, cut, turned, whatever you want to call it.
Old Apr 11, 2010 | 09:20 PM
Project's Avatar
You might want to check you rotors and pads. If the surfaces are different material ie. a ceramic pad they may be eating down your rotors vice versa. This could cause for uneven wear and the pulsating.
Old Apr 11, 2010 | 09:44 PM
How do I know if I have ceramic pads? The local Kost auto just put some pads on there...I didn't get details.
Old Apr 12, 2010 | 12:16 AM
GAU-8's Avatar
Dudefish is right. These are standard iron rotors. I just had mine cut and it worked out just fine. You can cut the rotors and keep the old pads. It's when you put new pads on that you want to scrub or cut the rotors. If your old pads didn't cut funny grooves into the rotor surface you should be fine.
Old Apr 20, 2010 | 11:30 PM
I was told by the guys at Kost tire and auto that since I've only had my pads for ab it over 2000 miles, it wouldn't make a diff...comments?
