Uneven drop in the rear
Old May 2, 2010 | 02:25 PM
NachoCheese's Avatar
Recently installed a set of DF210s, and the rear isn't dropped evenly. For some reason, the rear passenger side wheel sits about 1/2" lower than the rear drivers side wheel does. I've driven on them for 2 days now. Is there anything I can do to fix this?
Old May 2, 2010 | 02:32 PM
JIle342's Avatar
okay
Old May 2, 2010 | 02:39 PM
JBF's Avatar
JBF
^lol
OP if you sit in the car i bet its even.
Old May 2, 2010 | 02:53 PM
gabe3d's Avatar
maybe you forgot the spring mount on one side?
Old May 2, 2010 | 03:03 PM
SuperStezzyG's Avatar
im on DF210 no problems...
Old May 2, 2010 | 03:42 PM
davidxu's Avatar
let it settle first
Old May 2, 2010 | 03:57 PM
Fry - She'd have to be driving. And as long as I am physically capable of doing so, she will nevr drive over me, lol.
Finally - 230lbs probably evens it out, but I want it even when my fat *** ain't sittin in the car.
Gabe - I made sure I did everything correctly. And I know for sure the spring mount is in there. I wish it was that easy to fix though, haha
david - I'm gona give it another wek or 2. Hopefully me sitting in it will help even it out. I mean, it's not THAT noticeable, but it def is to me and I need it even or I'll go crazy. Love the drop it gives, though.
Old May 2, 2010 | 05:40 PM
MikeGrote's Avatar
I have the same thing, except my drivers side is about 1/4 - 1/2" lower than the pass side. i thought maybe is was the way i had rear sway bar preload set but that wasnt it. its not a big deal to me, just curious what causes this
Old May 2, 2010 | 05:42 PM
JIle342's Avatar
probably should just sell your G now.. LOL
but seriously, maybe they were installed wrong? I dk how that would happen, but it could..
Old May 2, 2010 | 05:59 PM
MikeGrote's Avatar
i have adjustable coils and have tried using those to compensate but something is keeping it uneven, idk
Old May 2, 2010 | 07:18 PM
I installed them correctly. The springs fit into the mounts exactly as they were supposed to, with the end of the springs in the little indents and all of that. I also lined up the top spring mount exactly like they were before I took them out to ensure I didn't mess nothin up. I guess it doesn't bother me THAT much, just wanted to see if there was an easy fix.
Old May 2, 2010 | 09:33 PM
MikeGrote's Avatar
at least now you know you arent the only one, but i havent figured mine out either yet
Old Jan 24, 2025 | 10:26 AM
Eurorose72's Avatar
Smooth speed demon
Has anyone figured out what could cause it to be uneven
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
itztwinki3
Oct 5, 2015 11:29 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
