Shim or no shim
Old May 10, 2010 | 12:38 PM
COMMANDOE's Avatar
Shim or no shim
I am replacing the pads on my 05 coupe (non-brembo) with akebono ceramic pads. Do you absolutely have to use the shims (oem) on the replacement pads. Or are "shims" only for oem pads?
thanks.
Old May 10, 2010 | 03:45 PM
AhchOO's Avatar
I got the same question also, Got a 04 but mine don't come with a shim. Do I need to get shims for them?
Old May 10, 2010 | 08:43 PM
COMMANDOE's Avatar
I believe some pads come with shims (mine did Akebono) I just did my front brakes today so I didn't use the oem shims. I think if you get pads without shims, common sense would be to use the oem? I think? lol
Old May 10, 2010 | 09:17 PM
G35fromPA's Avatar
Try to reuse the OEM shims if you can as it will cut down on squealing/noise. However, quite honestly, the OEM shims are acoustically designed for the OEM pads, so may not work as well on aftermarket pads anyway.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
dothemath
Oct 12, 2007 06:35 PM
Neal376
The M-Spot
May 16, 2007 09:46 PM
