How can I get Megan Racing coils to go lower in the rear?
Old May 19, 2010 | 09:51 PM
mitsuboost's Avatar
Question How can I get Megan Racing coils to go lower in the rear?
I already took off both rings/collars off the OEM style setup in the rear of my 05 coupe, and the car has a mild 1" drop. How can I go lower back there? can I get a set of sprint or another brand springs with lower rates? I don't really want to cut springs but i'm getting desperate -Megan Racing Street Coilovers. Thanks
Old May 19, 2010 | 09:59 PM
mitsuboost's Avatar
please help
Old May 19, 2010 | 10:03 PM
mitsuboost's Avatar
Old May 19, 2010 | 10:22 PM
Xet's Avatar
Xet
Stop posting, nobody is going to answer you within like 5 minutes. If you are only getting a 1" drop out of your megans as it sounds like in your post, you're doing it wrong.
Old May 19, 2010 | 10:26 PM
mitsuboost's Avatar
Thanks for assuming that i'm doing it wrong instead of posting helpful info
Old May 19, 2010 | 10:50 PM
Xet's Avatar
Xet
If you did some searching you would already know, bc has shorter springs and bc and megan are essentially the same. Trying doing some searching instead of posting every 5 minutes crying because you didn't do enough initial research and just bought the cheapest coils available.
Old May 19, 2010 | 10:52 PM
parhamm1's Avatar
Are you adjusting the height at the shock as well? Sounds like you're only messing with the spring perch. They should be done in tandem.
Old May 19, 2010 | 10:56 PM
parhamm1's Avatar
Xet- pretty harsh, tho your dead on with the lack of search function prior to making a thread like this. Noob- I would suggest asking one of our many suspension vendors before doing anymore here. Find one that sells megan's and get their answer. Tho I'm positive that you need to make adjustments on both the perch and the shock to get to the maximum drop.
Old May 19, 2010 | 10:59 PM
mitsuboost's Avatar
Ah yes someone with knowledgeable input! Yes the shocks are both completely lowered into their shock bodies and springs maxed
P.S. to the db above (XET) it's the valving on the shocks that are different not the spring rates between the BC's and Megans + not to knock them but u have form & functions which are not the most expensive or best system, baller.
Old May 19, 2010 | 11:12 PM
Deezflip's Avatar
do you have any pics of how low your rear is already? a pic would help to see if you are indeed lowered to the max. If i'm not mistaken, even with the optional shorter BC springs, you'll barely get the top of a 19in rim right at the fender.
Also, it may be a stupid question but it does happen to people here, did you make sure you remove the OEM upper rubber spring mount? and are your coils mounted with the perch collar on top? You do, however, have to keep the lower rubber mount in the spring bucket.
Old May 19, 2010 | 11:23 PM
parhamm1's Avatar
Good points above...
Old May 19, 2010 | 11:26 PM
mitsuboost's Avatar
I might have to look into the optional BC racing rear springs. That's a very valid question, yes the OEM upper rubber mount spring mount has been removed and the perch collar is facing up with the lower rubber mount in the spring bucket. Here is a picture to give u a better idea of where the drop is. Thanks for your help!!
Old May 19, 2010 | 11:43 PM
SxExCx's Avatar
It should go lower than that with the Megan setup right out of the box. It may take a day or so to settle. If you want to drop it lower than that, you can remove one of the red locking collars on the tops of the springs. This wont cause an problems because the if they are already screwed all the way to the top, the single remaining collar will snug up against the shock body instead of having to snug up against the other collar.
Calm down.
You're welcome.
Old May 20, 2010 | 12:01 AM
mitsuboost's Avatar
i already took both collars off thanks...
Old May 20, 2010 | 12:03 AM
Xet's Avatar
Xet
They are the same enough to use the shorter bc springs, which is exactly what I said in my previous post.
f&f are not the best but then again I knew I would want the ability to go as low as I wanted and f&f offers a lot more in that department than megan's.
Also from your pics you shouldn't be even close to being as low as possible. Here is a pic on my f&f which isn't anywhere near being as low as it can be, and megans shouldn't be THAT much shorter.
Check to make sure everything is installed correctly, other than that just wait till it settles. But even overnight it should be much closer to the actual height than how it is now.
