Vibrations after a few installs
Whats up everyone.. I just recently installed Tein cs(350z) with edfc, 20 & 25mm spacers, gt spec strut bar, spl endlinks front & rear, and z tube. My front fender well is at 25 1/2 and the rear at 26 1/2 on oem 18 wheels. After the coilover install, I noticed a slight clunking which has gotten slightly more noticable. And just after installing the strut bar and z tube, I am now getting vibrations which seem like is coming from the pedal or in that area, but can feel the vibrations in the pedal. Only happens when accelerating from a dead stop, but stops by the time I cross the light, or in low R's in a turn. How can I correct the issues at hand?
Has anyone experienced any of this? Any help would be greatly appreciated. Thank you
06 g35 coupe 5AT
Has anyone experienced any of this? Any help would be greatly appreciated. Thank you06 g35 coupe 5AT
anyone??
Resolved the vibration issue.. Had raised the strut bar a few mm to give more clearance above plenum, thought I had enough gap for slight engine movement but guess I was WRONG....
Still having the clunking noise though... Going to be checking my endlinks to see if any adjustments are needed and going to go over the front coilovers to make sure all is secured. Anyone else have any other tips before I take things down and put back together?? Have been searching for some answers with lil luck, but yet to resolve the clunking issue. Was told to remove hood liner because of the gt spec strut bar may be hitting the hood slightly, which could be causing clunking sound that makes it sound like it may be the coilovers. Do you agree?? And also have been told that tein cs tend to have the symptoms I am having. Is this also true?? Thanks once again to everyone and their two cents...
Machine Head
Sep 4, 2015 07:22 PM
