Lowering springs question
Old Jul 18, 2010 | 09:16 PM
G3V's Avatar
G3V
im planning to buy some lowering springs but i dont wanna buy a camber kit setup
if i lower my 2003 coupe on tein stech/ htech will i need camber work EVENTUALLY?? i dont wanna replace tires either ukno T.T
Old Jul 18, 2010 | 09:43 PM
Xet's Avatar
Xet
Are you going to put g35 or 350z springs on? S-techs you are going to at least need a camber kit in the rear, h-techs it's a good idea. You can run h-techs (particularly g35 ones although I prefer 350z) and get your camber close though. You will eat through tires a bit more unevenly but not that much and plus you can just get tires you can flip and voila! But either way if you want to save your tires as much as possible, I definitely say don't buy a set of springs until you can afford a camber kit, ichiba rear camber kits are only like $100 or so.
Old Jul 18, 2010 | 10:30 PM
G3V's Avatar
G3V
So regardless of what kind of springs i get, you would def recommend a camber kit huh.
i guess the ichiba rear for $100 is a pretty good deal!
so is there anyway i can get away with lowering the G without having to use a camber kit in the front? If so which springs should i go with?
rezendvous420
May 31, 2020 01:26 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
