Lowered car on Prokits and got an alignment:
Front Left Front Right
Camber: -2.2 -2.0
Toe: 0.06 0.04
I have the ichiba front kit, considering getting SPL or SPC. Will my tires wear out way too fast the way it is, should I upgrade the camber kit? What do you guys think?
Camber: -2.2 -2.0
Toe: 0.06 0.04
Just recently went through the same thing.. Got the ichiba's, which didn't bring me back to specs. So ended up getting the spc v2 to get me back in specs. My camber was pretty much the same as you, about a tenth difference. Long story short. Tires were at about 50%, and got pretty bald since. Got the spc arms in, but didn't have time to install the spacers, so can't give any feed back on that, just yet. Uneven tire wear is what I would assume, but I'm sure you will find your answer here with these guys on the forum.
How much postive camber adjustment did you get before going with SPC's? I'm thinking about getting another alignment at a different place. The place I went to was only able to get .4 degree positive adjustment on both sides. I feel like a place that knows what they're doing should be able to get a little bit more out of the Ichiba's. I could be wrong though
