NEED ALOT OF HELP. vdc light and slip
Old Aug 18, 2010 | 12:18 AM
DailyDrivenCoupe's Avatar
ok well i have done some research and i plan on checking out the brakes and fluid as well as the speed sensor on back of front rotors here very shortly but want more ideas of what i can check for in the morning. the car only has 44k miles. lowered on tien s-techs and aligned by nissan. ok four days ago it started raining really bad and went to meet someone to eat. i couldn't go over 35 without the car wanting to literally fishtail and i noticed the steering wheel was cocked really hard to the right like alignment was off. kept looking for tps to go off and pulled over and checked tires and they r all up. drove it in the dry and it has been fine and ive even gotten up to about 65 with no worries and steering wheels seems to be normal again. well it poured down today and did the same stuff on way to work and the steering wheel was once again cocked to the right like alignment was off but this time vdc light and slip came on. got to end of road turned the car off for five seconds then back on. they were off but the car still acted horrible. any other ideas. thanks guys!
Old Aug 18, 2010 | 06:17 PM
jon121587@yahoo's Avatar
I had the same problem with my vdc coming off but the reason for that was because i was running 10' wide tires in the front lol and my brakes felt like ****. a suggestion would be your front tires maybe?. yea u said that nissan was able to align your g with s tech tein. did u have camber kits at all just wondering thanks.
Old Aug 18, 2010 | 07:05 PM
idrive_MD's Avatar
what are your tire sizes and are they all the same brand and model? the brake fluid level issue with the vdc lights would not be causing driving issues. The only reason the vdc would act up is if it was failing, if there was a mechanical/electrical brake problem or if there was a problem with the tires or the size of the tires.
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
JermaineSanders
Aug 18, 2015 08:57 PM
MsFitFern
Aug 9, 2015 02:58 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
