SPL PRO Eccentric Lockout Kit questions
Old Sep 8, 2010 | 09:23 AM
88irocvert's Avatar
I've been reading that toe arms aren't the best way to set your toe since they also change another angle of your suspension geometry. I also plan on tracking my car which is another reason not to go with toe bolts since they apparently slip and therefore change your settings. I've been trying to find info on this board about the SPL PRO Eccentric Lockout Kit I saw on CZP. Any thoughts?
Old Sep 9, 2010 | 08:26 PM
obender66's Avatar
Are you talking about front or rear?
Old Sep 9, 2010 | 08:54 PM
88irocvert's Avatar
I would've been more specific but I didn't know we could even use toe bolts in the front. My question is regarding the rear.
Old Sep 10, 2010 | 09:53 AM
obender66's Avatar
Yeah, right-I had too many beers yesterday and wasn't thinking
Description is a bit confising, but looks that in order to use them you need to get both camber and toe arms. Then you completely ditch factory rear toe adjusters, which sit at the inside end of spring bucket. If you get both arms, then you should not have any issues with geometry-you will have full control over rear toe and camber.
IMO this is an overkill..eccentric bolts may slip when used with strut suspension, but inside the control arm...doubt that ..but then if you have 500 hp monster on racing slicks, then why not?
Old Sep 10, 2010 | 10:49 AM
88irocvert's Avatar
I only wish!!! No, my ride's only got bolt ons but it's also my daily driver so I'm concerned that, if I go with adjustable toe bolts, which I'm doing to prevent uneven tire wear, my suspension settings will shift with aggressive driving. I'm just wondering how much abuse they'll take without needing readjustment. Thanks for your feedback!!!
Old Sep 10, 2010 | 11:47 AM
GreenGoblin's Avatar
The goblin resurrection
I have them on my car, the spl arms very nice stuff.
jsimonk
Dec 22, 2023 03:49 PM
neight
Steering & Suspension
Aug 7, 2015 02:48 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
gabe3d
Drivetrain
Jul 22, 2015 11:49 AM
