350Z springs on G35
Old Nov 11, 2010 | 04:10 PM
Gspot82's Avatar
350Z springs on G35
Hi i just finnally got my 06 G35 and very new at this. I guess my question is how lower will my car be if put on a sets of oem 350z springs ? i just dont want to go too aggressive as this will be a daily driven car. Any helps will be appreciated. or if you have any picture of your car on those it would helps too.
Old Nov 11, 2010 | 04:25 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
There's lots of info on this topic if you want to dig a bit.
That said this is a very mild drop and completely fine for a DD car.
my '04 on z springs
Old Nov 11, 2010 | 04:55 PM
Gspot82's Avatar
Perfect.... thank you !!!
anymore pix ?.... anyone ?
Old Nov 11, 2010 | 05:09 PM
gmotion04's Avatar
the spring rates are different i read somewhere through my countless hours of searching that it wont be the same ride as G springs would be so it might not be as great as having 350z shocks and 350z springs thats what i did i have an 06 350z suspension with Z HandR springs
Old Nov 12, 2010 | 07:18 AM
dwrecckk's Avatar
I have a set of 06 350z springs with the revised spring rates if you're interested. From what I've read on the boards, the consensus seems to be that these springs will drop a sedan about 1" and the coupe about .5". Most drops over 3/4 of an inch will require a camber kit in the rear to get it back into spec, so these springs aren't a bad idea if you don't want to deal with camber issues.
Old Nov 12, 2010 | 01:08 PM
thomas18a's Avatar
get a set of eibach springs...they are nice. I got that on my G as well
Old Nov 12, 2010 | 01:12 PM
Jairen's Avatar
NOTE!: Any aftermarket 350Z spring will lower a coupe a additional ½” over and beyond the published drop amount for the 350Z. For sedan owners, the same applies to you, except you will gain a additional 1”, not just ½”
Oem linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004 (unrevised)
Front:314 Rear:342
Oem linear springs
G35 sedan's with non sport
Front: 283 Rear: 308
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2006 (revised suspension)
Front:314 Rear:427
Old Nov 13, 2010 | 03:33 AM
Gspot82's Avatar
Wow... Thanks you guys for all the info. Well the reason why i dont want to get aftermarket is because i do not want to void my warranty. I want to lower it just a little thats all.
Old Nov 13, 2010 | 12:17 PM
DrewLe's Avatar
My G on a full revised Z suspension. Gave me ~1 in. drop all around.
Old Nov 13, 2010 | 12:54 PM
G35Bandit's Avatar
nicee /\
Old Nov 14, 2010 | 12:21 PM
Gspot82's Avatar
Well i got my g at carmax with extended warranty, if i do the 350z springs swap would warranty voided ?
Old Nov 15, 2010 | 12:27 PM
Bozo954's Avatar
Here you go, G-Spot.............before & after Tein 350Z H-Techs (.08 Front / .07 Rear / No camber kit needed for .8 drops or less):
Rock on!!
Attached Thumbnails 350Z springs on G35-dscn0491.jpg   350Z springs on G35-ds-after-tein-350z-h-tech.jpg
Old Nov 15, 2010 | 12:41 PM
Bozo954's Avatar
Oh.......and mine's also an 06 Coupe, pretty much loaded, excluding Nav and Satellite radio - Sport, Premium, Aero, Rear-Active Steering packages.
In other words, no issues with the RAS rack & pinion in the back, i.e., I think I've seen some folks allude to problems when installing Eibachs and/or muffler upgrades.
Can't remember which - stands to reason it's the muffler upgrade (most likely) - but, long story short, you'll be fine.
Old Nov 15, 2010 | 01:17 PM
broke_as_ajoke's Avatar
Thats a nice drop.. all the way around
Old Nov 15, 2010 | 01:30 PM
Hotdawwgman's Avatar
Which Carmax. I bought mine at a Carmax also and my car is still covered with all the things I have done to it!
