Bent control arms. HELP
Old Nov 20, 2010 | 02:12 PM
Gstylin's Avatar
Question Bent control arms. HELP
The dealer told me that my front control arms are bent, and after researching i find that theirs upper and lower control arms and a whole bunch more stuff. I need to know what is actually bent. If it helps, my front tires are sittin kind of like / \ its not noticeable but its shredding the inner part of my tires. Can anyone help me diagnose what the actual problem is? Cause you kno how the dealers are and im def not taking it to them $$$$$. HELP pleeasee
Old Nov 20, 2010 | 02:42 PM
adamls2's Avatar
You should look at the vendor section for camber kits, the kit is the front arms which is what you need and the rear arms ( kit also comes with toe bolts) but if u only want the fronts you can buy them by thmselfs, you can PM mr.wong@statik he is a very good vendor
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
markbilo
Sep 30, 2015 01:33 AM
