drop help!!!!!
Old Nov 29, 2010 | 12:29 PM
g23nismooo's Avatar
drop help!!!!!
i am running 20 inch mesh wheels. in running 255 size tires in the back. i originally wanted coilovers but i dont think i want to go thaaat low. plus i think i found a shortcut. since oem 350z springs drop the sedan about 1 - 1.5 inches, if i get 350z lowering springs that lower a 350z 1.7inches, how much will it lower my 03 sedan?
Will the springs even fit?
Will it look better with a camber kit to get some stance?
thanks for your help
Old Nov 29, 2010 | 12:33 PM
CandlestickPark's Avatar
ill Sedan
Springs made for Z will lower your Sedan 1" more than it will on a Z.
Not sure what you are asking here.
Old Nov 29, 2010 | 01:45 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
i think he means should he get a camber kit and add more negative camber to make it look more....well you know or he might mean that he wants his alignment in spec....iono
Old Nov 29, 2010 | 04:43 PM
Blue Dream's Avatar
I drove ttrank's car solo
I'm pretty sure he meant to induce more neg camber since he referred to stance. However, what do I know.
Old Nov 29, 2010 | 08:09 PM
bound4VIP's Avatar
OP check the sedan FAQ thread that is stickied! you will find out just about everything you need to know. not trying to be a D**k. Like i was told when i started out here, read the FAQ thread before posting anything.
Old Nov 29, 2010 | 08:11 PM
4DGS's Avatar
Thread fail
Stop being cheap, buy coils.
Old Nov 29, 2010 | 11:22 PM
alexh521's Avatar
^ said he doesnt want to go that low
Old Nov 29, 2010 | 11:57 PM
ill Sedan
Actually he said he "thinks" he doesn't want to go that low and he found a shortcut via Z springs.
Translation: I want to go low but not slammed but don't want to spend the money on coils. I will almost be able to get as low as I want with Z springs for way cheaper.
OP, Blain (4DGS) is right, just save your money and get coils. Many of us have done the springs to coils route and its costed us more in the long run.
Old Nov 30, 2010 | 01:31 AM
G35xChicago's Avatar
Originally Posted by 4dgs
thread fail
stop being cheap, buy coils.
+1.....
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
