G35 sport vs non-sport
Old Dec 23, 2010 | 08:07 PM
si_driver's Avatar
If I were to purchase the sport version shocks for my 2003 G35 sedan non-sport version, would I also need to replace the coil springs or are they both the same?
Tom
Old Dec 23, 2010 | 11:21 PM
plonka's Avatar
Depends, If you buy knee high socks, you won't need to replace your springs because the socks will cover them.
Old Dec 24, 2010 | 03:34 AM
Footballmania32's Avatar
I would go ahead and buy the springs too. The 05+ sport springs have a higher spring rate. You'd benefit from the combo. IMO yes, just go ahead and do it.
Old Dec 31, 2010 | 04:29 AM
Gsedan35's Avatar
Coupe sport suspension changed in 05. The sedan did not.
With a 31lbs and 34lbs front and rear rate differance between sedan sport and non sport, no reason you can't run sport shocks with non sport springs. Where I disagree comes to a few aftermarket spring kits for the sedan that remove ride height AND have softer spring rates then oem, that I'm not ok with.
Old Dec 31, 2010 | 03:26 PM
prell's Avatar
I think the sway bars are slightly thicker on the sports as well, but definitely by the springs too, they are a different rate.
Old Jan 1, 2011 | 02:56 PM
Gsedan35's Avatar
03-04 sedan's all have the same sway bars reguardless of sport or non sport suspensions. In 2005 all sedan's received different sway's, again reguardless if they have the sport suspension or not. So for a sedan, the sport suspension is a shock and spring package only.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
multimut
Canada
Jul 26, 2015 08:43 PM
laksjd84
Jul 24, 2015 05:12 PM
