camber adjustment
Old Jan 4, 2011 | 11:35 PM
  #31
thebigg35's Avatar
does the stance coils come with the spring and the shock together or separate for the rear cuz im looking them up
Old Jan 4, 2011 | 11:36 PM
  #32
thebigg35's Avatar
r does the bc coils or the stance?
Old Jan 4, 2011 | 11:39 PM
  #33
eurodre's Avatar
you don't need true style they will be softer spring rates, something you don't want
once you go into true coilovers it means you know what you're doing and most of the people running them do not, if you wish to get those kind of custom settings like the stimulation you need to take about a few days to search the internet and then search again because i can almost guarantee you will screw it up so take it easy
those are the bc's
Old Jan 4, 2011 | 11:51 PM
  #34
thebigg35's Avatar
ok i see thanks and one last question does the bc's lower the car more then the tien basics?
Old Jan 4, 2011 | 11:52 PM
  #35
eurodre's Avatar
yes, tein basics are the worst coilovers known to man.. even cut springs have more prestige than basics
Old Jan 4, 2011 | 11:55 PM
  #36
thebigg35's Avatar
i can tell now i got them for 200 better the running nothing but im trying to get something better and so i can lean my tires in a lil
Old Jan 5, 2011 | 12:15 AM
  #37
thebigg35's Avatar
have u heard of d2 coilovers??? r they any good?
Old Jan 5, 2011 | 12:17 AM
  #38
ChinkyChoy's Avatar
https://g35driver.com/forums/search.php
Old Jan 5, 2011 | 12:20 AM
  #39
thebigg35's Avatar
or the ksport coils?
Old Jan 5, 2011 | 12:24 AM
  #40
ChinkyChoy's Avatar
Originally Posted by ChinkyChoy
i ll quote myself
Old Jan 5, 2011 | 02:43 AM
  #41
The Stimulation's Avatar
WWWOOOOOOOOWWWWWWww!!! 2k!!! That's also a lot of work as well. Is that just parts alone or did you go some where to get it installed?
Here's a break down:
Cusco upper A arms: 300 used on the forum
Battle Version rear camber arm: 150 new from friend that won them at a raffle
Battle Version rear toe arm: 250 (at the time, now 175..guess Alex decided to lower his prices to be more competitive)
Coilovers: Stance GR+ used on forums 900
Stiffer springs for rear from Stance: 80
Modifiying upper A arm to get an additional degree of adjustment: Approx 50-100 (got hooked up and several things were done)
Total = Almost $1,800. Does not include installation of coilovers, all camber arms, toe arms, and alignment. That'll put it over 2k for sure. If new, you're looking at probably another 500 or so more.
If you're not going to run more than -4 camber in the rear, stick to OEM coilovers (spring separate). As Dre mentioned, the true type will have a softer spring rate in the rear and is only really needed if you need to run toe arms. With approx -4 camber you just need rear camber arms and toe bolts.
As for the K-sport coilovers....those, bc racing, stance, megan, and maybe a few others are very similar. Just different colors, spring rates, preloads, height adjustment and dampening.
Old Jan 5, 2011 | 03:54 PM
  #42
thebigg35's Avatar
i know this might sound dum but i was wondering can u lower the rear by taking one of the adjusting plates off?
Old Jan 5, 2011 | 03:59 PM
  #43
Matzo Ball's Avatar
Originally Posted by eurodre
the front can go to the ground the rear has a ring taken off, i can take off the final ring and get maybe 1/4" lower
like I said stance gr+ for the same price and stiffer spring rates
needs spacers all around. Not enough poke
Old Jan 5, 2011 | 04:47 PM
  #44
Yes, removing the collars will help you gain some extra lowering space, bout half an inch I'm gonna guess.
Old Jan 5, 2011 | 06:36 PM
  #45
eurodre's Avatar
haha lately the cars my car has been around has made my -3 camber look like 0
