what else do i need
Old Jan 12, 2011 | 10:55 PM
mattesatinblack's Avatar
what else do i need
ok so i need help i have these parts coming soon and i am trying to figure out what else i need to get to have a soild suspension
i am running coilover and camber arms
so the question is what other parts do i need
GTSPEC Rear Strut Brace
GTSPEC Front Strut Brace
GTSPEC 4 Point Mid Chassis Reinforcement Brace
GTSPEC Rear Lateral Arm Brace
GTSPEC Rear Lower Tie Brace
GTSPEC Front Lower Tie Brace
Old Jan 12, 2011 | 10:57 PM
ChinkyChoy's Avatar
sway bars?
Old Jan 13, 2011 | 03:38 AM
tyau's Avatar
to have a solid suspension?
You would need more than just bars bro.
You would be needing some upgraded bushings for the control arms, subframes, and also some spherical tie rod ends.
But then, after you have all the bushings replaced, with sway bars and coils and all your braces, with everything stiffended up, you will start to realize just how soft the chassis is with all your other reinforcements. At that point you would be needing some roll bars. I have driven full out cars prepped for drifting, with the body seams spot welded and tubbed. The G35 even with almost every suspension bolt-on available would still feel loose and soft in comparison.
