Energy suspension bushings for 350z/G35
Old Mar 19, 2011 | 11:43 PM
SDGenius's Avatar
Front set
http://www.z1motorsports.com/350_g35...7111461ed277f4
Rear set
Old Mar 20, 2011 | 12:52 AM
HwyDrftr's Avatar
yep those are them (the rear set), which goes where? and there are none with an I.D. to fit the long inserts...
Old Apr 6, 2011 | 02:02 PM
Jeff92se's Avatar
Red Card Crew
Nice. Isn't the front missing one on the control arm?
Old Apr 6, 2011 | 02:56 PM
Daniel@Z1's Avatar
Ill email you a pdf file of the install manual
Old Apr 6, 2011 | 03:30 PM
HwyDrftr's Avatar
No, that is where the ball joint goes.
Old Apr 6, 2011 | 05:17 PM
MikeDG's Avatar
Originally Posted by skidz88
Does anyone know when the kit will be available for order? Talked to my parts guy and he said no dice so far.
A vendor on here is selling them already:
https://g35driver.com/forums/suspens...-bushings.html
I ordered the front arm kit last week. It should be on my doorstep when I get home today.
Old Apr 6, 2011 | 05:20 PM
Jeff92se's Avatar
Red Card Crew
Are these cheaper than whiteline?
Old Apr 6, 2011 | 06:34 PM
HwyDrftr's Avatar
Z1 has the kit http://www.z1motorsports.com/350_g35...oducts_id=5122 Whiteline does not sell the compression rod bushings so it's hard to compare but the control arm bushings from Whiteline are ~$100. for now Energy only sells the compression rod bushings with the whole front kit.
Old Apr 7, 2011 | 02:24 PM
Jeff92se's Avatar
Red Card Crew
I note that the whiteline stuff is $50, $40 for each bushing so the entire front kit might end up being cheaper vs buying one by one from whiteline
Old Apr 7, 2011 | 05:17 PM
Daniel@Z1's Avatar
In the next week or so im going to have all the G/Z ES front bushing available separately
Old Apr 7, 2011 | 07:03 PM
HwyDrftr's Avatar
WhiteLine prices are by the pair, that would leave about $70 for the compression bushings.
Old Apr 7, 2011 | 07:14 PM
vinco's Avatar
I've had my ES front end set for 3 weeks. My Hyperflex Master Kit (complete car) will be here early next week! So, I'll have an extra front set to sell.
Old Apr 7, 2011 | 07:27 PM
Jeff92se's Avatar
Red Card Crew
How to you like your ES stuff? And pm me how much you'd want for the front set
Old Apr 7, 2011 | 10:27 PM
Choleaoum's Avatar
same here, i'd like to know how the ride is and if any noises were being made?
Old Apr 8, 2011 | 10:12 AM
  #30
Daniel@Z1's Avatar
We put some of the bushings on the front of a car that we have here and they ride great. you can tell a big difference in the front. As for the noise as long as you grease them they are quiet
