Clunking in Front Passenger side
Old Mar 8, 2011 | 10:05 AM
Gnorth35's Avatar
Question Clunking in Front Passenger side
Hello,
New member here looking to see if anyone has figured out the "Clunking factor" with these cars? I've had this Clunking sound for about five thousand miles so for. I had the sway bar bushings and end pieces replaced but the noise is still there. The mechanic says the Struts seem to be okay, but now the noise sounds even louder with every bump and pothole. Any results from some of you guys going through this also.
Gnorth35
Old Mar 11, 2011 | 10:55 AM
vinco's Avatar
Compression rod bushings failed. Common problem. Stay tuned for a good aftermarket solution in the next few weeks.
Old Mar 28, 2011 | 12:08 PM
Gnorth35's Avatar
Vinco,
Thanks for the update... now I'm looking at the front wheel bearing assembly and hub. Does anybody know if they make an aftermarket product for this?
Old Mar 28, 2011 | 12:13 PM
vinco's Avatar
Aftermarket part for hub/bearing should be available at your local parts store. If a used one would be acceptable, then try online at car-part.com A 350Z one would work just fine as well as a G35 one.
Old Mar 29, 2011 | 11:41 AM
RADIOGUY21's Avatar
I've been dealing with the clunk/wobble/pop noise on my drivers side. I've also replaced the endlinks and sway bushings since they were the cheapest wear items to start with and it seems to have gotten worse with time.
From what I gather, it can be the lower control arm bushing, strut mounts, compression rods. I wish I knew exactly what it was, I dont want to just throw money at it.
Old Mar 29, 2011 | 02:42 PM
Gnorth35's Avatar
Radoiguy21,
This came from Vinco:
Gnorth35
Old Mar 29, 2011 | 05:50 PM
RADIOGUY21's Avatar
I have had my compression rods replaced before, so I dont think they are the problem. They didnt make this clunking noise when they went bad, rather a squeaking/creaking noise.
rezendvous420
May 31, 2020 01:26 PM
mbe093
Lights
Oct 2, 2016 11:09 PM
rping
Jul 26, 2015 09:53 PM
wylin
Lights
Jul 18, 2015 06:12 PM
