Rear Coilover Install Question
Old Mar 10, 2011 | 11:35 AM
carlo107's Avatar
hey everyone I own an 07 g35 coupe and have purchased a set of coilovers and the spc camber kits. My question is that stock the rear has the spring and strut seperately but my coilovers are one piece with the spring going over the strut. When I install these does this mean that now where the stock spring used to be, is now going to be empty and I just put the coilover where the stock strut was? I know this may sound stupid but I just want to double check to make sure this is done correctly. All the DIYs I found are showing people installing the aftermarket spring and strut seperately and couldnt find any that show a coilover being installed in the rear. Thanks for the help!!
Old Mar 10, 2011 | 12:28 PM
JaE35's Avatar
Moderator
G35 Sedan
There are true and OEM style coilovers. You have the true setup. Should be enough info for your search criteria now
Old Mar 10, 2011 | 12:34 PM
carlo107's Avatar
ok thanks ill try searching that
Old Mar 10, 2011 | 12:36 PM
gmotion04's Avatar
take out the spring bucket and buy a toe arm!
Old Mar 10, 2011 | 01:09 PM
carlo107's Avatar
I have toe bolts coming with my spc kit, so basically i found that it goes where the strut used to be and you cut a hole in your trunk carpet to adjust the coilovers. What is that toe arm your talking about? Is it ok if i just leave the OEM spring spot empty and just take the spring out?
Old Mar 10, 2011 | 01:12 PM
gmotion04's Avatar
yes you can leave it i just suggested it for weight savings
Old Mar 10, 2011 | 02:02 PM
carlo107's Avatar
icic ive actually never heard of it, is its purpose just to adjust toe in the rear? Also is it a direct fit in replacement of the spring bucket?
Old Mar 12, 2011 | 08:59 PM
JaE35's Avatar
Moderator
G35 Sedan
Yes and yes!
Old Mar 13, 2011 | 11:39 AM
DogStar's Avatar
http://www.splprosuspension.com/SPL_RTA_Z33.html
Check the vendors or occasionally private classifieds for some. You can get used at around 200 for a set. New they range but several of the vendors have them. This (or similar as in diff brand) is what you want. They do make them for the rear active steering too should you need them.
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
