How low can you go....
Old May 3, 2011 | 12:08 AM
dphillips2011's Avatar
Without having to buy a camber kit and having your camber all messed up? I want a conservative drop of around an inch if possible, because i hate how high the X model sits compared to my old coupe.
If possible, how low can i go with JUST springs? which springs would be best?
would any other OEM struts/springs combo drop me without having the tire wear issues?
I know this subject is beaten to death, but I can't find exactly what im looking for. Thanks in advance!
Old May 3, 2011 | 08:14 PM
bump. anyone?
Old May 3, 2011 | 08:42 PM
herrschaft's Avatar
It varies too much, there's no exact answer. Drop the car to where you want it then see if the alignment can be brought back to spec.
Old May 3, 2011 | 11:38 PM
4D05G35's Avatar
Buy coilovers, set your ride height then go from there.....
Old May 3, 2011 | 11:43 PM
4D05G35's Avatar
Or 350Z suspension will give you your conservative drop........but a search would have yeilded that.
Old May 4, 2011 | 02:25 AM
Xet's Avatar
Xet
+1 on this.
but thumbs down on the deceiving title.
Old May 4, 2011 | 06:27 AM
iiiiiekoiiiii's Avatar
U have an X... Not so much in the front. Rears I maxed out with shorter struts and 200mm springs on Bc coils but front, After I tucked the front tires, I clipped every suer cap on the floor, talkin about finger gap btwn cross member under the engine and the pavement...
Few days ago, they slammed 2nd gen sedan and Coils, Guy couldnt leave the block, came back to the shop to lift the front...
DRG35R
Jan 31, 2016 07:14 AM
Rinaldi
Dec 2, 2015 05:29 PM
aaron3719
Sep 29, 2015 10:12 AM
wow600rr
Sep 28, 2015 11:50 AM
Detailed Image
Sep 28, 2015 07:04 AM
