Spacer size help!?
Old Jul 13, 2011 | 11:39 PM
Papi Chulo's Avatar
Question Spacer size help!?
Alright so im running a stock 2005 G35 and im thinking of getting a drop and most likely running TanabeDFs. I also want to get spacers with the drop because i want that clean flush look. I was thinking of getting 25mm in the front and 20mm for the back. What do u guys think? any other ideas or suggestions?
Old Jul 13, 2011 | 11:52 PM
Polishthrust's Avatar
I assume that you are running oem 19s. Do 25 front and back, you will need to roll fenders. Dont do 25 front and 20 back, it will look weird.
Old Jul 14, 2011 | 12:15 AM
Papi Chulo's Avatar
my bad i meant 25mm back and 20mm to the front. 25mm is sounding pretty good though and ive been doing a lot of research and thats what people seem to do a lot.
Old Jul 14, 2011 | 01:18 AM
As long as you are rolling fenders you might as well go 25mm front. It will be more flush. Thats what im running.
Old Jul 14, 2011 | 09:12 PM
Papi Chulo's Avatar
with 25mm in the rear i still need to roll the rear fenders? and with 20mm in the front will i still need to roll the front fenders?
Old Jul 14, 2011 | 09:25 PM
Xet's Avatar
Xet
I never had to roll my fronts dropped on z-htechs with 25mm spacers. I had 25mm all around and I liked them, although I would do 25f/30r if I did it again.
Old Jul 14, 2011 | 10:02 PM
Papi Chulo's Avatar
so u think ill need to roll fenders with tanabes? its like .4 of an inch more in the rear and front so will it make a differene?
Old Jul 14, 2011 | 10:06 PM
Adil_G35's Avatar
What tires are you running?
Old Jul 14, 2011 | 10:17 PM
Papi Chulo's Avatar
in the front i have 225/40zr19 and in the rear im running 245/40zr19
Old Jul 14, 2011 | 10:24 PM
Adil_G35's Avatar
okay so ur on stock tire sizes. Are you planning to keep the same sizes? If you drop your car I'd recommend going down to a more low profile tire. It would look much better with an aggressive offset
Old Jul 14, 2011 | 10:32 PM
Papi Chulo's Avatar
yea im planning on keepign the same tire size for now, im just wondering that with my stock tires, if a tanaba drop and 25mm spacers all around would fit on my car without rolling the fenders.
Old Jul 14, 2011 | 10:39 PM
Adil_G35's Avatar
Nah you should be fine. Even at stock height theres still gap. Depends how big of a drop you want.
Old Jul 14, 2011 | 10:44 PM
Papi Chulo's Avatar
with TanabeDF i will be dropping 1.7" in the rear and 1.3" n the front
Old Jul 14, 2011 | 10:47 PM
Adil_G35's Avatar
Yeah with spacers i'd go ahead and roll em bro. Roll em and you can drop it as much as you want
Old Jul 15, 2011 | 04:13 AM
DrewDrew's Avatar
25mm all around. roll your fenders. you'll look great. make sure to get an alignment. you'll be running with negative camber all around unless you get camber kits w/ toe bolts. negative camber isn't a problem, but if your toe is out of wack and can't get it back in spec, close to 0, your tires will be f*cked in less than 500 miles. make sure you have the financials to properly drop your car.
