Rubbing before lowering?
Old Jul 31, 2011 | 08:25 AM
noles4423's Avatar
So I'm trying the modding thing now and I dropped on a set of 20x8.5 20x10 245x35 F and 275 30 R 25mm on my coupe. I knew from reading the forum that my car would instantly trasform to a 4x4 and it has!
Now I'm wanting lower it but after driving for a few days I've noticed a bit of rubbing in the rear. Is this normal? Sorry but I did check other threads and couldn't find any answers.
Thanks
Old Jul 31, 2011 | 10:38 AM
irishsig's Avatar
What are u droppped on now?
When u say "rubbing" do you see evidence on the tire or do u hear it when u drive.
Have u rolled the rear fenders yet?
Pics would really help.
Old Jul 31, 2011 | 10:41 AM
noles4423's Avatar
Not lowered at all....still stock setup. Have not rolled fender. It's not continous rubbing but I do hear it when I drive over a slight bump. I'll post a few crappy iphone pics
Old Jul 31, 2011 | 10:55 AM
noles4423's Avatar
Not lowered at all....still on stock setup. Here are a few pics I just took from my phone.
Attached Thumbnails Rubbing before lowering?-myc.jpg   Rubbing before lowering?-c.jpg
Old Jul 31, 2011 | 11:03 AM
irishsig's Avatar
U shouldn't be rubbing at all with that kind of clearance.
Your shocks may be blown.
How many miles on the car?
Old Jul 31, 2011 | 11:59 AM
noles4423's Avatar
Ahh...good point. Just over 100k. Well....I better start shopping for shocks!! I wish I could afford coilovers but shock and springs for now.
Old Jul 31, 2011 | 12:04 PM
irishsig's Avatar
Tokico HPs are affordable and match up well with aftermarket springs.
The difference is night and day
Old Jul 31, 2011 | 01:32 PM
toro12's Avatar
20 Year Member
Fender looks plenty clear, ever for bumps. Check if inside of the wider rear wheel/tire is rubbing the shocks.
Old Jul 31, 2011 | 01:47 PM
chatt350gt's Avatar
^^toro took the words right out of my mouth
Old Jul 31, 2011 | 02:01 PM
gtoor1990's Avatar
+1 , even if your shocks were bad you would havint any rubbing issue, only thing it could be is rubbing shocks.
Old Jul 31, 2011 | 02:22 PM
irishsig's Avatar
I see what you guys are talking about but if I'm not mistaken he's running a 25mm spacer on the rears.
Maybe it's +25 offset.
Either way I don't think that should cause rubbing with the rear shocks.
Correct me if I'm wrong, don't want to misguide OP.
Old Jul 31, 2011 | 02:54 PM
noles4423's Avatar
no spacers on the rear
Old Jul 31, 2011 | 04:13 PM
irishsig's Avatar
Not really, he said the tires rub when he goes over bumps.
A 10" wide rear wheel at 275 30R20 with a +25 offset would not rub on the shock,
unless something was damaged on the suspension.
Old Jul 31, 2011 | 04:26 PM
gtoor1990's Avatar
A 10" wide rear wheel at 275 30R20 with a +25 offset would not run on the shock,
Whoops my bad lol was flying through the thread didint read that part about going over bumps lol
Old Jul 31, 2011 | 04:46 PM
irishsig's Avatar
Hey Gtoor, checkin out your sig pic.
Got any pics of your G?
That that coupe has crazy neg camber goin on.
