squeaking front end
Old Aug 6, 2011 | 09:34 PM
beniscooler850's Avatar
squeaking front end
I am getting a squeak from the front of the car when i go over bumps. Does anyone know what it could be.
Old Aug 6, 2011 | 10:16 PM
4D05G35's Avatar
Search out "compression rod bushings" thats most likely your culprit. Otherwise if your struts are worn out they can squeak as well.
Old Aug 6, 2011 | 10:21 PM
I just checked my bushings all looks good nothing looks out of wack
Old Aug 7, 2011 | 12:20 AM
4D05G35's Avatar
I haven't changed mine out yet, but I need to. From what iv'e heard/read it is a very common problem. Mine look fine from a quick visual, but they are toast.
Have you changed anything recently? Any other bushings or parts related to the suspension?
Old Aug 7, 2011 | 01:36 AM
04G35NYC's Avatar
Check your sway links and sway bushings.
Old Aug 8, 2011 | 01:52 AM
thanks but i went out took out the sway bar bushing everything looks good
Old Aug 8, 2011 | 02:50 AM
jtmobsta's Avatar
Does it squeak when you turn your wheel left and right while stationary? or is it just over bumps?
Old Aug 8, 2011 | 08:29 PM
just over bumps turns are good steady and no squeak
gonna go and take out the sway bar bushings and grease them up and see what happens
Old Aug 18, 2011 | 01:16 PM
Drew113's Avatar
Ban Hammer Expert
mine queaks for both what would need to be replaced or checked?
tiguy99
Mar 1, 2016 11:42 AM
wuppiedog
Aug 7, 2015 11:16 AM
ddietz97
Jul 26, 2015 06:16 PM
newg37
Jul 26, 2015 09:32 AM
