ABS/RAS/VCD/SLIP light all on!?
Old Oct 8, 2011 | 06:29 PM
Algy's Avatar
Ok like the title says. I have all these lights on for some reason? I had a diagnostic machine read the codes and it gave me two codes.
1. R front speed sensor - 1107
2. RAS circuit - 1137
Ok I dont know what caused all these lights to come up randomly but what I do know is when it came on. My front passenger camber A arm came loose and gave me a bunch of negative camber. I took it to firestone and let them readjust it but I watched him do the whole process bc I had to tell him how to do it. After he finished, I just barely drove it off the parking lot and all the lights just lit up on my dash?!?!
My dad owns an auto shop and we have been looking underneath and all and checking all the sensors and replacing them but its still the same issue and codes popping up.
Does anybody have any idea what it is? Or what is causing it?
Old Oct 8, 2011 | 07:51 PM
Algy's Avatar
Oh I have a 2006 5at g35 coupe with RAS if that helps.
Old Oct 9, 2011 | 07:46 PM
Algy's Avatar
bump
Old Oct 10, 2011 | 09:50 PM
Algy's Avatar
Anyone have some insight?
Old Oct 12, 2011 | 02:59 PM
Algy's Avatar
Since no one had a clue, Ill just give an update.
I read a few threads on here about how low brake fluids, brake pads, and off alignments can cause these lights to go off. I checked all those things and it was a negative. Everything was okay.
I got my car up on a lift and my dad and I started to look at all the sensors and connectors. We just decided to disconnect all of them and give them a clean and swap the connectors from right to left bc they are the same thing. We also swapped the rubber magnetic hub on the both sides to the opposite. With that, once we installed everything back together and reset the car, everything was fine. No code or anything. I guessing it was a bad connector or it was dirty. Hope this helps anyone else with problems.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
