Quick Question Regarding Sliding Pin Bolt Size
Old Oct 31, 2011 | 02:16 PM
ThatOneDude's Avatar
I've been having scraping noises and recently discovered something on the driver side front wheel was the culprit. Went in to take a look, and noticed the bottom sliding pin bolt on the caliper is completely missing. So, I figure I could walk into a nearby hardware store (small little place) and simply buy a new bolt. However, I have no idea what size to look or ask for. Can anyone help me out? Thanks.
Old Oct 31, 2011 | 02:22 PM
19kdrill's Avatar
Thinking you might be looking for something like this:
http://www.autozone.com/autozone/par.../N-jkfexZ8knjf
Old Oct 31, 2011 | 02:25 PM
Yeah I believe that's it. I'm going to just remove the other one and bring it with me and ask. Thanks!
Old Oct 31, 2011 | 02:32 PM
19kdrill's Avatar
No problem. I believe the bolt in there is a 12mm x 1.0 (which is a finer thread than your standard 12mm x 1.25). Found out the hard way when mine stripped and I tried to replace it with one from Lowes...
GL!
rob.g
Old Oct 31, 2011 | 03:19 PM
Local hardware store didn't have it due to thread being too "coarse". Nowhere else is really in walking distance, plus I'm at work, so I can't really spend much time away. Hoping Autozone would have it in stock and not just be an online thing.
Old Oct 31, 2011 | 03:40 PM
19kdrill's Avatar
They had them in stock at my local auto zone. I'm pretty sure it's a common item (like maybe fitting Maxima's and Altima's too...)
Old Oct 31, 2011 | 03:44 PM
Excellent. Autozone is the second nearest place to here. Just need to find time. Thanks again.
Edit:
The person there said they didn't carry that specific strength rating (10) so I got nothing... Should I have just said "Let me try with this weaker rating (8)" or what? Both places I went to recommended a specific place for me to go to, but that's a bit farther away... fml...
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
