Which rear sway bar is flat?
I'm looking at new rear sway bars. I want to know which brands make the bar that go below the exhaust pipe. I don't want the kind that has the hump in it to go over the pipe. I want it to be flat all the way across the bottom. I saw the 350evo swaybars and wondered if anyone else made them like that.
ENVautoDetailing.com
350EVO are the only sways that are flat in the back. I have a set on my car and I painted the rear red since it was rusting. You can buy mine for the right price
http://www.google.ca/search?q=g35+sw...w=1920&bih=899
are 350evo ones discontinued or they are currently out? They typically only run them in batches so they will be around for awhile then scarce again when they sell out? i would email them and ask 350evo stuff is typically not real easy to find.
Interesting. Does it scrape at your height?
Do you have them set wrong? Mine have never scraped and they are not the lowest point on the car either?
The OEM chassis brace is the lowest thing in the rear and I have scraped it lots!
a flatter veiw
a flatter veiw
Yes it scrapes every so often.
Gord, my 350evo rear sway is less than 2" from the ground just like my front subframe. I know your car is low but I'm on a 235/35/19 rear, don't need the wider (and taller) tires like you do for the FI
my sedan also doesn't have the oem rear chassis brace like coupes/Z's do
I haven't been under my car in quite awhile, but I didn't ever notice it being that low
my car isn't real low either though, the rear OEM coupe brace is pretty scarred up on mine though and looking at the pictures the sway bar is the next lowest thing after that brace.
rezendvous420
May 31, 2020 01:26 PM
TreeFiddy
Aug 10, 2015 06:50 PM
