abs pulsating when taking right hand on/off ramp
Old Dec 31, 2011 | 06:13 PM
sushiboiiii's Avatar
so i recently came on the problem. if i go on left hand turns it doesnt happen. but if i go right it does slip light starts flashing and it slows down and it stops after 40mph. this started after i got air ride which im not sure what it has to do with it, but if anyone can shed some light please help!
Old Jan 5, 2012 | 09:11 AM
05Scoobyroo's Avatar
Sounds like an alignment issue.
Old Jan 5, 2012 | 04:19 PM
bigc's Avatar
Wings Nation
check your ABS sensors. you may need to have the stealership hook-up a CONSULT-II to see if that's the issue.
Old Jan 5, 2012 | 09:06 PM
as for alignment i just had it aligned if that helps but yeah ill def hit up the dealership to see if it the abs speed sensor is an issue.
Old Jan 5, 2012 | 09:20 PM
Frankieg35's Avatar
Did u hit the abs sensor when putting in your airride??
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
miata007
Aug 17, 2015 04:36 PM
