Clicking sounds at my wheels??
Old Jan 16, 2012 | 11:12 PM
Natmats's Avatar
This clicking only happens at low gears. Basically when i'm starting in first, i hear a couple clicks once i get going then when i shift to second and get a couple clicks as well.
the clicks:
- sounds like a high-pitched version of when you make clicking sounds with your tongue against the inside of your teeth
- not persistent
- maybe it's the brakes?
anyone experience this?
my car specs are listed on my profile but it's a '03 g35c w/ brembo brakes (replaced the rear rotors and brake pads 8/24/2011)
THANKS!!
Old Jan 17, 2012 | 09:13 AM
viceversa's Avatar
See if this helps: http://my350z.com/forum/engine-drive...rear-axle.html
Old Jan 17, 2012 | 11:22 AM
Natmats's Avatar
Originally Posted by viceversa
Thanks for the link. I feel like my clicking isn't as predictable and less frequent. I was going to try to record it but I actually had to shoot about 5 min of video to capture it clicking.
Let me trim the video down and post it on here.
Old Jan 17, 2012 | 11:50 AM
sharkcityG's Avatar
It's your axel clicking. You need to take it out clean it and grease it and put it back in. Problem solved
Old Jan 19, 2012 | 09:29 PM
Natmats's Avatar
here's a very short video of the clicking sound. it occurs at :04. I have a feeling it's just the brakes. Are brembos known for this?
Old Jan 19, 2012 | 09:30 PM
Natmats's Avatar
check the vid i posted above
Old Jan 20, 2012 | 08:39 AM
viceversa's Avatar
sounds like the axle click to me. should only be coming from the rear wheels. the link I posted earlier is a complete DIY on how to resolve it.
Old Jan 20, 2012 | 09:15 AM
sharkcityG's Avatar
110% sure it's your axel. Mine did it also it's an easy fix. If you're handy do it your self. Take out both rear axels clean n grease it up and put it back it. That'll problly cost u 20 if DIY. If you want to take it to a dealer ship your looking at $100+
Old Jan 20, 2012 | 11:10 AM
Natmats's Avatar
i'll do it myself! i'll let you know how it turns out!
Old Jan 21, 2012 | 05:02 PM
viceversa's Avatar
Goodluck to ya! shouldnt be too hard. I used Valvoline SynPower Synthetic Grease which can found at most local auto stores. Fixed mine about a year ago and still no more clicking.
Old Jan 28, 2012 | 07:28 PM
Natmats's Avatar
thanks to all! i just fixed it with my pops! no more clicking!
it turned out to be the rear L axle. the hardest part was removing the axle. but i lavishly lathered it with Mobil1 Synthetic Grease (~$8). thanks for everything! cheers!
Old Jan 28, 2012 | 08:59 PM
sharkcityG's Avatar
Nicee ......problem solved
Old Jan 30, 2012 | 09:06 AM
viceversa's Avatar
glad it worked! that clicking becomes extremely annoying
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Detailed Image
Jul 24, 2015 12:31 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
papo020
Jul 17, 2015 10:30 PM
