spc camber bolts / arms
Old Feb 10, 2012 | 10:11 PM
santod's Avatar
please help me understand camber arms vs cam bolts. From what i can understand from posts I might be able to use just bolts to adjust camber and toe. Is it true that SPC bolts in the stock arms and spring perch will allow me to adjust out 350z rear shocks and springs? I can install these part on my own if I know what to do. I dont want to waste money on spc camber arms if they are not required. thanks for all that reply.
Old Feb 10, 2012 | 10:33 PM
jbwrecked's Avatar
http://my350z.com/forum/brakes-and-s...ion-101-a.html
^^read up on that. everything you need to know
You need a rear camber kit to adjust camber. SPC rear camber kit works
The rear camber kit replaces the oem camber arm
Toe bolts adjust toe in the rear. Trimming/Dremeling is required. SPC toe bolts work
Toe bolts go in the rear control arm i believe? Where the spring bucket is.
I think thats how it goes. Peeps feel free to correct or chime in
seagrasser
May 3, 2022 09:43 AM
jilljann1
Jul 21, 2020 08:12 AM
bigmike
Sep 17, 2015 01:58 PM
DRG35R
Sep 16, 2015 05:33 AM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
