Suspension Mod For Summer.
Old Feb 11, 2012 | 12:34 PM
acee's Avatar
Addict
Top Speed Coilovers
http://compare.ebay.com/like/230724874299?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y
Planning on getting these coils for my G coupe. Anyone had these and what's the ride comfort like? Also I'm planning to get either 19" or 20" rims.
Either way i would still need a camber kit right?
i've also been told to get sway bars first before coils? why ?
Is there anything else I would need when getting coils?
Old Feb 12, 2012 | 06:50 AM
acee's Avatar
Addict
anyone know about these coilovers ?
Old Feb 12, 2012 | 05:22 PM
brandon1978's Avatar
Originally Posted by Ace of Spades
http://compare.ebay.com/like/2307248..._lwgsi=y&cbt=y
If you drop an inch or more you may want to get camber kits to save your tires from increased wear. You might want to install the coils first and see what the camber is with the height you want. Then you can decide if you want to pay for a camber kit or pay for tires more often.
Sways are probably the most cost effective suspension mod you can make. There is no reason you have to get sways before coil overs.
You will need an alignment. If you are installing the coils yourself, get a cotter pin set.
Old Feb 22, 2012 | 10:45 PM
acee's Avatar
Addict
thanks very informative.
Old Feb 24, 2012 | 06:36 AM
acke15's Avatar
I hope you didn't buy those junk coilovers.
Old Feb 24, 2012 | 12:44 PM
acee's Avatar
Addict
havent bought them yet im getting rims first but i was waiting for more input on the coilovers first of course whats your input on them? i know a memeber here twalls has them, but idk how it rides?
Old Feb 25, 2012 | 12:45 AM
acke15's Avatar
What's your budget? Most coilovers under 1500 are junk.
Old Feb 25, 2012 | 12:49 AM
acee's Avatar
Addict
honestly anything lower than 800 : / i was even considering just getting springs and camber kits and call it a day...and struts as well...idk too much work plus springs are forever cant even adjust them...
Old Feb 25, 2012 | 12:53 AM
acke15's Avatar
On that budget, just get some springs and a rear camber kit. That should run around 3-400$
Old Feb 25, 2012 | 12:55 AM
acee's Avatar
Addict
what about shocks/struts?
Old Feb 25, 2012 | 08:20 AM
acke15's Avatar
I'd get tokico d specs. Run around 500
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
joeslates
Sep 11, 2015 11:19 PM
socaldavid
Sep 5, 2015 04:35 AM
INVADER_6MT
Sep 3, 2015 01:47 AM
