Energy Suspension Bushings
Old Feb 24, 2012 | 01:22 PM
G35CO's Avatar
Got my Stillen sway bars and I’m planning o replace my bushings because they are old. I'm trying to decide if I want to go with the factory bushings or the energy suspension bushings.
When I search the web I found this company that selling them specifically for our cars but the bushing sizes didn’t match our car sway bars sizes and were different from the bushings numbers recommended on the sway bars tread.
http://www.energysuspensionparts.com...i%2BG35%2B2003
I called the company and they told me to call the manufacture. I called energy suspension and talked to a very friendly guy that told me that they just came out with the bushings for our car and the bushings were tested on 350z for fitment. I told him that the 350z and G35 have the same size sway bars and the bushing they advertise for our cars are smaller then what Nissan/Infiniti advertises sizes. He told me that maybe the 350z got different size sway bars then the G35.
He kept telling me that the universal bushings that match the size of our sway bars will not fit correctly on my car because if they fit correctly the company will not spend money and research time to create new specific bushings for our car if the universal fit correctly.
Which one should I buy???????????????????????????????????????????
Old Nov 10, 2012 | 05:56 PM
prelude9569's Avatar
I have a 2008 journey sedan and I am about to put Stillen front and rear sway bars on and would like to know which energy suspension sway bar bushings to buy? Can't seen to find a clear answer anywhere. I get conflicting info when trying to research.
Anyone have Stillen sways on a 2008 sedan? Which sway bushings did you use? Please help.
Thanks
Old Nov 10, 2012 | 06:46 PM
K.C's Avatar
K.C
bump for some good knowlegde!
Old Nov 10, 2012 | 09:28 PM
Sen's Avatar
Sen
Thanks
As far as I know, Energy Suspension only makes one type of sway bar bushing for a particular car. So if you want to replace the fronts and rears, get a set of fronts and rears made for your car's year.
Not sure about the stillen sways as opposed to stock. You may want to double check the size difference compared to stock, but I would imagine the bushings will fit most sway bars.
Old Nov 10, 2012 | 11:22 PM
Thanks. I finally found the info I was looking for. The diameter of the front Stillen sway is slightly bigger than the rear. 1-1/16" & 1" respectivly. Energy suspension makes both of these sizes so I ordered accordingly.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
AJC128
Nov 1, 2015 11:55 AM
AL8782
Oct 3, 2015 10:26 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
