Rear Passenger Wheel Noise?
Old Apr 8, 2012 | 09:45 PM
trocketsone's Avatar
So I installed new TEIN springs on the wheel 2 days ago and since its been fine but tonight I noticed a sound coming from the rear passenger side wheel...
It doesnt happen when I accelerate only when I brake or just let the car roll... and it especially happens at lower speeds...
Also it only occurs periodically ... meaning the sound would happen and then go away and then happen again like a cycle... as if something was stuck on one part of the rotor and the caliper was grinding it?
Its not a squeaking noise... more like something brushing on something else kind of noise...
I dont know whats wrong or where to start.... anyone have suggestions/same problem?
Is it the spring?
Old Apr 9, 2012 | 06:49 PM
saywat?'s Avatar
wheels have springs?
Old May 19, 2012 | 10:21 PM
Bump.... anyone?? Still have this issue... Now it has gotten progressively worse.
The noise would only go away if I accelerate. Once I stop accelerating (letting it roll) it would make the scraping/grinding sound.
If I apply the brakes (and have driven it for more than an hour) it would make a sound.
If I apply the brakes (and I've driven it less than an hour but more than 20 min or so) it won't make a sound.
Help please !!
** Also forgot to add I tried the 6'o clock and 12' o clock trick on the wheel and tried turning it for play... no play at all...
Last edited by trocketsone; May 19, 2012 at 10:25 PM. Reason: Left out some information
Old May 22, 2012 | 09:30 PM
bumpp... anyone??
Old May 26, 2012 | 10:59 PM
Just if anyone has a problem like this in the future... it was the wheel bearing and wheel hub.
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
