How to adjust ride height on Stance GR
Old May 6, 2012 | 05:09 AM
g-spots78's Avatar
how do you guys adjust the ride height/low in the rear on Stance GR coilover. My shock and springs are not come in one unit for the rear...plus my coilover are very stiff does not matter how soft i dial....Thanks
Old May 6, 2012 | 09:11 AM
Dubi2087's Avatar
You most Likely started messing with the spring and and screwed up the preload. You adjust the height with the actual shock not the spring.
Old May 10, 2012 | 01:57 PM
o3LRG's Avatar
Hey OP do you have the true style or the OEM style. If u have the oem version. There's a write up with good info on how to adjust it.
If u have the true style ones u should have only moved the bottom collor and adjust the whole shock body. Up or down.
Old May 10, 2012 | 01:58 PM
o3LRG's Avatar
Use the search button....
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
Fox843
Nov 7, 2015 05:43 PM
master111
Sep 25, 2015 08:32 PM
