350Z vs G35 brakes
Old Jun 6, 2012 | 01:52 PM
money042's Avatar
350Z vs G35 brakes
Is there any resource out there that compares the OEM brakes of each car? And the break down of the changes between model years?
example, early years vs brembo's, then came revup models, then the akebomo's and so on
Generally, if I need to know if 05 Z brakes are compatible with a 07 G coupe, etc
Old Jun 6, 2012 | 03:36 PM
money042's Avatar
Found some part numbers for comparison:
41001-CM40A -- 2005-2007 G35 Right Caliper (Also 2006 350Z share these part number)
D0206-ZA500 -- 2005-2007 G35 Right Rotor
41001-AM801 -- 2005 350Z Right Caliper (Same parts# as 2004 G35)
40206-AM800 -- 2005 350Z Right Rotor
These are cars with DE engines, I didn't look at HR engines.
Old Jun 6, 2012 | 04:00 PM
suprasam's Avatar
I don't have a resource but I'm sure brembos from early year G/Z fit all non brembo G coupes to '07. They require no additional brackets.
05-07 Gs did not have a brembo option.
The non brembo Gs from 03-04 had single piston fronts/rear calibers. The 05-07 have a two piston front/single piston rear caliper.
The Akebonos came out with the new G37 coupe and are now offered in current G models (not sure about the G25).
The 05 z brakes should fit no problem
The revup models had no affect on G brake packages because they came with 05-up 6MTs which did not have a brembo option.
If anything I would compare the part numbers for the "spindle" or "hub" parts because that's where the calipers mount.
Old Jun 7, 2012 | 10:27 PM
G35fromPA's Avatar
Check out infinitihelp.com and nissanhelp.com for brake size specs. You can look at all model years.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
