BC Racing Rear Adjustment
Old Aug 22, 2012 | 05:17 PM
datsiK.G's Avatar
How do I adjust the rears on BC racing BR coilovers? I know you have to adjust both the spring and the shock. Take off the bolt that holds the strut, jack up the spring bucket, then adjust? Do I adjust both the spring and the strut the same length? I know if this is not done correctly, clunking will likely happen.
Old Aug 22, 2012 | 06:23 PM
Frankieg35's Avatar
If I remember right u adjust the spring in the bucket where u want your suspension setup and drop the car off the jack to set hight, take the wheel back off and jack up the spring bucket so the spring gets tension on it and measure from top to bottom where the shock mounts, then adjust the strut and install..
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
