How do you adjust this rear shock? (Pic included)
Old Sep 9, 2012 | 02:25 AM
wonton1017's Avatar
I loosened the perch with the arrow pointing to it and tried spinning the threaded tube from right to left, but it won't move whatsoever.
I loosened the bolt on the bottom of the strut to try to turn it that way, but when i turn it, the entire thing rotates (top is still connected).
I sprayed wd40 and rust check lube all over it and hammered it to let the liquid go inside but still won't move. Waited 3 hours and sprayed it and hammered it again every 3 hours but no luck.
Shocks are too long right now, spring bucket is ~2cm loose which is causing the spring to bottom out and make a pop noise.
Old Sep 10, 2012 | 09:32 PM
VMRWheels's Avatar
Sounds like the lower mount is seized up a bit. You might have to take the shock out to unstick it.
Old Sep 10, 2012 | 09:38 PM
gary c's Avatar
That's a coilover right and not a shock? I know it's a PIA but I'd remove it and shoot a little WD40 on the threads then break it loose, carefully. Can we assume you got the correct wrench to adjust the collar?
Gary
Old Sep 10, 2012 | 10:10 PM
VMRWheels's Avatar
^He mentioned he was able to break the collar free, but he can't actually rotate the shock itself within the lower mount.
rezendvous420
May 31, 2020 01:26 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
