Noise after sway bar installation
i installed the rear sway bar this past weekend (haven't installed the front). All seems ok except that when I go over a speed bump I hear a clacking noise, as if something is loose. Maybe something is rubbing...not sure. I rasied the car and everything seems correct. I used new OE bushings and end links.The only thing I didnt do was lube the bar bushings because I thought that was only necessary for poly bushings. Other than that, I have no ideas. Does anyone have any suggestions?
There seems to be plenty of thread exposed on the ends of the endlinks. I didnt have a torque wrench handy but will double check the correct torque when I am down there again. Thanks.
rezendvous420
May 31, 2020 01:26 PM
