Buying New Rotors, Opinions needed Pleeaase!
Old Jan 26, 2013 | 04:32 AM
CFernando17's Avatar
Brakes Buying New Rotors, Opinions needed Pleeaase!
Soooo, my front rotors are no more and need replacing. I have been doing some research as for the rotor design (drilled, slotted, etc.) I've come to the conclusion that I prefer cross drilled & slotted rotors. I've been looking around at different brands and so far come up with these 2 choices. Please let me know what you guys think or if you have any suggestions please LMK asap. I need to order by Monday
http://www.stillen.com/product/brake...0xs-59029.html
http://www.tirerack.com/brakes/brake...ance+Wheel+Pkg
Old Jan 26, 2013 | 10:59 AM
Blue Dream's Avatar
I drove ttrank's car solo
A lot of members have used R1Concepts for their rotors including me in the past. they use Centric blanks and their prices are insanely low. Check them out.
Old Jan 26, 2013 | 02:37 PM
Thanks Blue will do a bit of research on them today
Old Jan 26, 2013 | 03:08 PM
I've read up on the R1's for a bit on forums and other reviews and it's making me a bit skeptical about buying them....talk of good quality but bad experiences with rusting ....
Anybody have experience/reviews on the DBA 4000 series XS rotors??? Heres the link
http://www.autoanything.com/brakes/61A3530A0A0.aspx
Old Feb 4, 2013 | 05:05 PM
mCat85's Avatar
I just ordered some new rotors myself after getting tired of feeling my warped fronts (like an earthquake every time i pressed!); although I haven't used them before, I've been told that cryo-treated rotors last a lot longer than non-treated. they come in plain/slotted/drilled i think, across different brands. i went w/ the plain because of cost. I'll follow-up again after a few weeks of driving w/ these to let you know in case you're still looking =].
http://www.tirerack.com/brakes/brake...tor&cat=Rotors
Edit: Oh, and if you find anything about these that i haven't mentioned already, do tell!
Old Feb 5, 2013 | 02:07 PM
KNS Brakes's Avatar
DBA 4000XS are good rotors and the heat treating will help with the durability and longevity of the rotor, I've never been a fan of drilled rotors, too much can go wrong especially if you're on track. Slots will add some bite and torque as well as help with pad issues under repeated hard braking. Drills will do pretty much do the same, but will also decrease the integrity of the rotor.
Depended on the year of your vehicle I have some DBA street series slotted rotors that are on clearance. They are for a 02-04 Non Brembo G35
If you end up not going with a drilled or slotted rotor, Centric Premiums are definitely the way to go, good quality and cheap.
-Nick
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
sahizzle110
Jul 29, 2015 11:36 AM
RedBaronK
Jul 27, 2015 03:19 PM
