Problem with SPC camber kit
Old Feb 13, 2013 | 12:14 AM
Tukeeg35's Avatar
hey all,
So I installed my front and rear SPC camber kit recently, but I'm having trouble with the driver front brakes. When I apply them while driving it sounds and feels like the ABS is kicking in. Do you guys think I should add another one of the washers to space out the sensor? would that fix the problem?
Any insight would be helpful.
Old Feb 13, 2013 | 12:20 AM
Frankieg35's Avatar
How many did u put in??
Old Feb 13, 2013 | 12:35 AM
Tukeeg35's Avatar
2 on each side
Old Feb 13, 2013 | 12:39 AM
Frankieg35's Avatar
Hmm, it calls for two so I would start at none or one and work your way up..
Old Feb 13, 2013 | 12:43 AM
herrschaft's Avatar
No ABS lights? I had similar instances shortly after having mine installed except my light came on as well. Only happened on steep driveways when taken at an angle, not sure what changed but mine hasn't done that in over 1.5 years.
Old Feb 13, 2013 | 12:54 AM
Tukeeg35's Avatar
I have my ABS light, VDC off, and SLIP lights all on but i think that's because i haven't had the alignment done yet.
I'll try your suggestion Frankie and ill let u guys know how it works...Im out of town till sunday though so ill have updates by monday.
Old Feb 13, 2013 | 12:58 AM
herrschaft's Avatar
Now that sounds more like a spacer problem.
Old Feb 13, 2013 | 02:02 AM
Xet's Avatar
Xet
shim problem, search around on the forums and you will find the problem discussed in more detail and what you need to do to fix it
Old Feb 17, 2013 | 01:23 PM
Tukeeg35's Avatar
I added another washer to the ABS bracket to space it out more and it looks to have solved the problem but I still have all the lights showing on my dash.
Gonna clear the codes and see what happens.
Old Feb 17, 2013 | 03:33 PM
Tukeeg35's Avatar
Everything seems to be ok again, the Christmas tree of dash lights was off when I went back to clear the codes!
Thanks all for your help
Old Feb 20, 2013 | 02:14 PM
Tukeeg35's Avatar
Update:
Still have the same problem...Thinking of selling the kit and opting for the more expensive SPL kit
Old Feb 22, 2013 | 01:45 AM
Algy's Avatar
this is very tedious. I had the same issue with the SPC camber kit.
You have to install some washers or spacers for the ABS sensor. When done correctly, the lights will turn off trust me.
It took me forever to get it right. Just make sure the ABS sensor isnt rubbing on the magnetic strip on the bearing hub. If so, it will destroy the magnetic strip and the sensor will not operate correctly causing the ABS lights to turn on. I had this happen to me.
Too much spacing and the sensors dont sense the magnetic strip on the bearing hub.
It has to be just right.
Old Feb 22, 2013 | 04:20 PM
Tukeeg35's Avatar
Thanks for the reply Algy, how many washers (the ones that came with the kit) did you use on either side? I started with two on both sides and have been trying to figure it out independently on both sides...maybe that my problem.
Did you space both sides evenly is my main question i guess lol
Thanks again!
Old Feb 22, 2013 | 04:41 PM
BowWizzel's Avatar
Idk, did you install the hub shim correctly & the L bracket piece that SPC supplies to support the sensor? When I install mine I turned the hub with only 2 washers for the ABS sensor & it sounded like some rubbing was happening so I just added one on each side for a total of 3. Not one problem with ABS, slip, VDC at all.
Old Feb 22, 2013 | 04:57 PM
Tukeeg35's Avatar
Mmk,
The way I understand ABS system to work is that if the sensor is too far away the system thinks the wheel isn't moving so the ABS pump kicks in every time you touch the brake pedal.
I just went and set both sides to one washer and so far it seems to have solved the problem. I'll go drive it a bit more in a short while and let you guys know what up!
