Help with adjusting height Megan racing coilovers
Old Apr 18, 2013 | 09:17 PM
izzueeek's Avatar
Hi
Recently I have bought the Megan racing street series coilovers. I got everything installed correctly at a shop. So today I wanted to lower the front a bit more so I followed the instructions and tried to lower it. But for some reason it did not work
There is this black collar that is above the bottom perch which is connected to the brake lines. Do i need to remove it first?
Could someone that is rolling with the megan racing coilovers help me out?
I tried searching but could not find anything.
Thanks
Old Apr 20, 2013 | 07:08 PM
Wisco-G35X's Avatar
G35
Loosen the lower spanner nut and then twist the collar clockwise till it reaches ur desire ride height. The upper 2 nuts that are holding the spring, leave it alone.
Old Apr 20, 2013 | 07:26 PM
Xet's Avatar
Xet
Don't adjust the preload (the one holding the spring taut), you bring up the lower spring perch ONLY!
Old Apr 21, 2013 | 02:28 PM
izzueeek's Avatar
Okay thanka guys. I got it
Apparently they gave me the wrong instruction booklet
Old Apr 25, 2013 | 12:39 PM
Divindclown's Avatar
Megan Racing Street Coilovers
Hey,
Did you guys need to purchase addtional parts for the alignment. No one knows out here. Some were talking about getting a rear end strut bar. Thanks for any and all advise.
Old Apr 25, 2013 | 02:26 PM
Xet's Avatar
Xet
You'll want Front camber kit and rear camber kit with extended toe bolts (unless you have true style coilovers - then you can go with a toe arm instead of the extended toe bolts if you wish). Go with SPC or SPL brands only.
Strut bar doesn't relate to your aligning
Old Apr 25, 2013 | 03:07 PM
Megan Racing Coilovers (alignment)
Ok, thanks! Anyone know where I can find the SPC for less than $426 bucks. I'm on a budget. Suspension is not cheap
Old Apr 25, 2013 | 07:06 PM
Xet's Avatar
Xet
not sure of current prices, but either vendors or watch for members who sell theirs
Old May 22, 2013 | 05:28 AM
purp35's Avatar
so im having the same problem with these megans, can anyone help me figure this out.
ok i loosen the lower spanner nut then adjusted it to where i wanted to lower it and then i twisted the whole strut clockwise to lower it then tightened the lower nut back up, but when i put the wheel back on the ride height has not moved, now i have dramatically moved the whole strut up and down several times and it seem to do nothing!! it doesnt lower it or raise it. it does nothing! i cant seem to understand it
can anyone help?
Old May 22, 2013 | 06:57 AM
Blue Dream's Avatar
I drove ttrank's car solo
You bought the wrong car if you're on a budget and want to modify it. I'm just sayin..............
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
master111
Sep 25, 2015 08:32 PM
