2010 370z brakes on 03 sedan???
Old May 8, 2013 | 12:29 PM
Odejc's Avatar
Question 2010 370z brakes on 03 sedan???
I'm looking to upgrade my brakes. I found a great deal on a full 2010 370z rotors, and calipers (non-brembo). Will these bolt on to my 03 rwd sedan? These aren't the big 14" rotors so I doubt I need that special bracket. I'm hoping and guessing that I can just bolt them right on.
12.5" front rotor
2piston front
1piston rear
Old May 8, 2013 | 12:54 PM
PAIXAO's Avatar
If I had to take a wild guess, I think that you would need the same bracket used for placing the Akebono brakes on earlier model (pre 07) sedans
Old May 8, 2013 | 11:28 PM
Odejc's Avatar
I checked the specs on the non-brembo calipers and rotors. They are the same as the 05-06 sedans. So once I get them...I'll confirm..
Thanks for your feedback.
Old May 9, 2013 | 02:16 AM
shyun1250's Avatar
Probably will need the same bracket.
Old May 9, 2013 | 07:49 AM
PAIXAO's Avatar
2010 370Z does not have Brembo Calipers. The only option for brakes is the Akebono brakes.
Old May 9, 2013 | 10:43 AM
DEMoLITIoN's Avatar
My buddy just upgraded to G37 calipers and had to use the Z1 bracket.
http://www.z1motorsports.com/350_g35...oducts_id=5332
Old May 9, 2013 | 09:17 PM
Odejc's Avatar
Ok. Well I guess this seller has his info a little mixed up.
Here is the post/sale link with pictures.
http://my350z.com/forum/brakes/57526...ors-lines.html
jsimonk
Dec 22, 2023 03:49 PM
vstypicals
Jul 20, 2015 10:55 PM
mushu
Jul 15, 2015 03:55 PM
