rs*r 350z ti2000
I know i can get them from Japan. The reason I posted this was because I was wondering if someone had a set. didn't want to pay 150 bucks for shipping
That seems like the only place..I hit up 2 vendors here and waitng for a reply on the same springs in TI and 350z rsr down springs...One member here has run them and complained the the front dropped 1.1 but rear only dropped .6 on his g35..Should have dropped to 1.1 in rear...Do your research like me before you pull the trigger...
Maybe look into the g35 coupe RSR which do a 1.1 even drop all around 315/315 spring rates...Progressive
Hmmm .6 in the back? Damn I've never heard of someone's settling like that. Ive done quite a bit of research and decided to go with the rsr's and then I find out I've gotta order them from Japan lol. Ill probably just go the tein 350z route... I've heard some bad things about the ride of the eibachs
RSR coupe version should be an even drop...its the 350z verions that seem to not be even in the rear,even thou they say a .5 more drop will happen...I wanted the (350z versions of rsr because of better spring rates) But not if it wont drop the rear correctly..
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
