Clicking noise from rear brakes
Old Oct 11, 2013 | 01:48 AM
CHIG35CL's Avatar
Angry Clicking noise from rear brakes
2003 G35 sedan. When I brake about 40-50% of the way I get this loud clicking sound. This is a sound clip of it, http://johnberry258.tumblr.com/post/63712128911. I cant figure out what it is, and I tried pulling the hand brake but it wont do it then. It also feels like my rotors are warped from 50-35 mph, I thought it was the front brakes so I replaced the rotors with drilled and slotted one, new pads, and cleaned everything up with a wire brush, and it also didnt shake at all when using just the hand brake. What could this be from? Any help is much appreciated
Old Oct 11, 2013 | 02:39 AM
Eric@TCGMiami's Avatar
Sounds like an infamous axle click....
Old Oct 11, 2013 | 04:17 AM
CHIG35CL's Avatar
Thats what I thought initially but it only does it while braking
Old Oct 11, 2013 | 09:14 AM
LoSt180's Avatar
Well, the hand brake is actually a small drum brake inside the rotor, so you won't hear the same noises or feel vibrations from a warped rotor anyway. After listening to that sound clip, it does not sound like the axle click. It sounds more like something is rubbing. Check clearance of the dust shield all the way around the rotors and bend them back a bit if needed.
Have you inspected the rear brakes yet? You replaced front stuff already. I'd start with cleaning everything up, greasing all the pins and shims on the back of the pads, and inspect bushings.
Old Oct 29, 2013 | 11:35 AM
PewPewPewter03's Avatar
I have the same exact problem but on my passenger front brake. I was inspecting it yesterday and took the wheel off and rotated the hub while I had a friend apply pressure to the brake. It seemed to be coming from the thin metal brackets attached to the caliper. Interested in what solution you come up with. I just put some PB blaster to lube them a little but I'll report back when I drive the car to see if that helped.
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
papo020
Jul 17, 2015 10:30 PM
emorehs
Jul 17, 2015 09:45 AM
