Help with rotors
Old Nov 6, 2013 | 04:21 PM
seddon's Avatar
Help with rotors
Tried searching but could not find any helpful info, i have an 05 g35 sedan. In 06 I installed a wilwood bbk, 4 piston with a 13.25 inch by 1.1 inch rotor. I now need new rotors. I called wilwood and they said they don't make a 13.25 inch rotor. Does any one know where I can get the rotors?
Old Nov 6, 2013 | 04:40 PM
Texasscout's Avatar
Have you tried looking for a name on the edge of the rotor, that's where they put it most of the time. Most likely someone "married" the rotor and calipers together as a "kit", the rotors may be a different brand.
Old Nov 13, 2013 | 05:04 PM
KNS Brakes's Avatar
It is possible that it was a Wilwood put together kit. This is where someone makes a rando Wilwood caliper fit on a stock size rotor. According to the sizes you listed, that is not a stock rotor for your vehicle, but it could be from a different vehicle.
Look for any kind of information on the edge of the rotor, manufacturer, sizes, p/n anything.
-Nick
Old Nov 21, 2013 | 11:34 AM
Todd TCE's Avatar
You installed a BRAND X kit using Wilwood calipers. Not a Wilwood kit. Start by calling the company that made it. That's if they are still around of course. There are no 13.25" Wilwood rotors in any width. If you strike out shoot me a pm and I'll try to help you out.
Old Nov 21, 2013 | 10:08 PM
totopo's Avatar
How about going the other way? Go from the caliper model you have then finding which rotor normally goes with it.
Old Nov 21, 2013 | 10:23 PM
KNS Brakes's Avatar
You don't get it.
Somebody made a kit using a WW caliper and 'some other' rotor.
So you have to find out who chose what 'other rotor' and get a replacement.
It is most likely a Coleman rotor as they are the most common/easiest to get made.
And even if not - with proper measuring there is likely a Coleman rotor that can be spec'd
Old Mar 31, 2015 | 09:15 PM
JHereth22's Avatar
Seddon what grill are you using????
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
