rebuilding non-brembo caliper
Old May 6, 2014 | 02:29 PM
whoisthis's Avatar
I've been searching and searching for DIY of how to rebuild 06 (dual pistons) non-brembo brake calipers, and i could not find a single DIY..
The reason why i think i need to rebuild my calipers:
MPG has dropped down significantly.
It's hard to turn the front wheels by hand when they are off the ground.
I smell something burning after driving.
One of the piston seals was busted.
I will replace the sliding pins as well.
Please help me figure out how to do this DIY
Old May 6, 2014 | 02:41 PM
Texasscout's Avatar
Yep, you need to rework the calipers. Go to the auto store and get a kit, follow the instructions to the letter. Clean and grease everything that moves.
Here is ONE vid of many on youtube, this is a Z but it's the same:
Old May 6, 2014 | 03:12 PM
whoisthis's Avatar
i did find this video before but this is for brembo, not non-brembo.
I couldn't find a DIY for non-brembo DIY..
Old May 6, 2014 | 03:21 PM
Texasscout's Avatar
Principals are all the same.
Old May 6, 2014 | 03:43 PM
whoisthis's Avatar
it requires more work than i thought.. I didn't know that you need an air compressor to do this. Also caliper disconnected from the hose.
If my problem is the sliding pin, then will new sliding pin fix the problem without replacing rotors and pads? They probably have uneven wear if the brake pads have been dragging all this long.
Old May 6, 2014 | 04:06 PM
Jeff92se's Avatar
Red Card Crew
If the seal is busted, don't you have a massive brake fluid leak all over your pads etc?
Old May 6, 2014 | 04:14 PM
whoisthis's Avatar
seal/rubber ring around the piston is ripped. There is no fluid leakage that i can spot. And the brake fluid level is at same spot.
Because there is no leakage, rebuild is not necessary?
Old May 6, 2014 | 04:17 PM
Texasscout's Avatar
The dust shield is busted not the piston seal.
Old May 6, 2014 | 05:25 PM
Jeff92se's Avatar
Red Card Crew
Dragging doesn't mean the caliper needs to be rebuilt. It could be the slide pins dragging, the pads could be dragging in their slots. But I suspect that if you look at the caliper, one side of the rotor and one pad will be really worn. This would indicate that floating nature of the caliper isn't functioning. That points to the slide pins IMHO. Especially if their dust boots are torn etc...
Old May 6, 2014 | 10:02 PM
coffeysm's Avatar
You could just order a reman from RockAuto for like 150 bucks if I remember correct. You then send them back your old caliper all parts included and they give you a 60-70 dollar core back. That's what I did with my front passenger caliper it was seizing and causing a hit in my MPG as well.
If you go that route paint the new calipers with some rustproof paint. They come painted, but it isn't rust proofed, lol. Ask me how I know....
A lot easier and faster then rebuilding a whole caliper.
Old May 7, 2014 | 03:46 AM
whoisthis's Avatar
i should replace the slider pin before i go ahead and rebuild the caliper.
Old May 7, 2014 | 08:33 AM
Urbanengineer's Avatar
You got it!
Make sure to grease it up well !
Old May 7, 2014 | 08:41 AM
whoisthis's Avatar
You got it!
i've experienced the rubber piece on the sliding pin swelling up before. Perhaps this lube might be the cause...http://www.autozone.com/autozone/acc...er=826455_0_0_
So im planning to get this one instead. http://www.autozone.com/autozone/acc...ier=10772_0_0_
Old May 7, 2014 | 08:54 AM
Okay! Don't overgrease. That may be the cause of your issue there.
Old May 7, 2014 | 01:19 PM
whoisthis's Avatar
Ill keep that in mind .
Also, the sliding pin with rubber piece goes in to top part of caliper, correct?
The part number i see from dealership is 41217
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
seagrasser
May 3, 2022 09:43 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
