Rough braking at high speeds
Old Jul 2, 2014 | 08:13 PM
kr33p's Avatar
So I just purchased a 2004 g35 sedan and I'm loving every minute of it. However, the only issue I seem to be experiencing is when I go to stop by pressing on the brake pedal. I feel that I get a rough stop and even some vibrations. This only happens at high speeds.
What do you think can be the issue?
One thing that I did notice however is that all the tires are different brands but unsure in size. Could this be the issue?
Thanks for any and all help!
Old Jul 2, 2014 | 08:33 PM
gary c's Avatar
Rough Stop doesn't explain what you're feeling, however I would check your front suspension and brakes. Every neighborhood has an independent brake/alignment shop that knows their job, find yours! Steering wheel shimmy happens when your rotors are warped, is that what you're experiencing? Having different brand tires on each corner might have negative driving results for sure! Begin by having your suspension checked out then check with www.thetirerack.com for a set of new tires...Good Luck & Enjoy the ride!
Gary
Old Jul 9, 2014 | 02:12 PM
KNS Brakes's Avatar
It is very possible the pads that are on the car are very cheap. They have overheated and just left uneven pad deposits on the rotors. Those uneven deposits are the cause of the vibration you're getting.
Get some pads that pair well with your driving style, try to salvage the rotors by getting some sand paper and cleaning them. Install the new pads and call it a day.
-Nick
Old Jul 10, 2014 | 02:07 PM
shady909's Avatar
Your rotors might be warped.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
ddietz97
Jul 26, 2015 06:16 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
