Front Suspension Feels Loose.
Old Aug 4, 2014 | 10:58 PM
JHereth22's Avatar
Well I've gotta get
Shocks
Ball Joints
Springs
Sways
Sway Bar
Then the rest..
All in the order. I'm going to spend $500. Or should i tune the car? Idk man
Old Aug 4, 2014 | 11:04 PM
ScraggleRock's Avatar
Don't forget upper control arms (kinetix v2), spacers, rear adjustable control arms and toe bolts.
Haha trust me, man. It'll all save you money on tires in the long run. Plus it makes your car feel much higher end suspension wise.
Old Aug 5, 2014 | 04:43 AM
dofu's Avatar
20 Year Member
Coupe or sedan?
Get some adjustable tie rods while you are at it.
Old Aug 5, 2014 | 02:59 PM
Tolboothwilley™'s Avatar
what bushings have you actually replaced? There are a lot of bushings and if you are feeling like the suspension is loose, it is likely to be the bushings (Lower control arm and compression rod are the most common).
These other mods will help with performance, but not fix a "loose" feel unless your shocks are blown.
Old Aug 5, 2014 | 03:03 PM
He already did the c-rod/LCA poly bushings. He's good there.
Old Aug 6, 2014 | 12:52 PM
JHereth22's Avatar
I just need the front end to feel stiff. I hate getting above 120 and the car feels like it's gonna fall apart.
Old Aug 6, 2014 | 12:58 PM
JHereth22's Avatar
Plus those upper arms are next paycheck.
Old Aug 6, 2014 | 02:10 PM
I have never felt this in a G
How is your alignment?
Old Aug 6, 2014 | 03:19 PM
Its probably off. My alignment was **** in dead stock form. I hate this cars stock suspension.
Once you get those adjustable arms, your car is gonna feel like a whole new wooorrrllldd. A new fantastic point of view.
Old Aug 6, 2014 | 03:50 PM
JHereth22's Avatar
Well my alignment was just done. And next paycheck man!
Old Aug 6, 2014 | 04:07 PM
Haha, I know I know. I'm just excited for you. BtW, I would invest in a lifetime alignment if I were you. Every time you tear apart that front end it needs to be realigned.
Old Aug 6, 2014 | 04:12 PM
JHereth22's Avatar
Haha me too. This should make my car pretty nice.
Old Aug 7, 2014 | 08:52 PM
JHereth22's Avatar
So ordering them now. Mevotech lower ball joints. Megan Y Pipe, Mevotech front sway bar links. What's another thing for around 120 that's good I should get?
Old Aug 7, 2014 | 08:54 PM
Toe bolts are about $30
A pair of spacers is about $120
Old Aug 7, 2014 | 09:02 PM
  #30
JHereth22's Avatar
Why toe bolts? I literally just got new ones from nissan a month ago. And spacers are for looks.. Rather put that 120 to performance.
