Weird Noise coming from left front wheel when turning right
Sep 8, 2014 | 12:46 AM
Hey guys, a noise just started coming up when I do a right turn. It kind of sounds like I'm scraping on my fender but I don't think that's the case cause I'm on stockers and I never hewed this in the past. The sound is only coming from the front driver side wheel and only when I turn to the right. Does anyone know what the noise is? Thanks in advance
Reply 0
Sep 9, 2014 | 12:40 AM
anyone know?? its not a clunking or a grinding noise..
Reply 0
Sep 10, 2014 | 04:09 AM
drikx....i just got the same thing cople of days ago.....mine start when i go in the freeways not in the street and I'm wondering what that sound is.....it sound like I'm hitting or scriping or rubbing somewhere
Reply 0
Sep 10, 2014 | 04:38 AM
Check fender liner
Reply 0
Sep 10, 2014 | 09:47 PM
i dont see anything scrapping. i researched cv joint and wheel bearing but it sounds nothing alike
Reply 0
Sep 11, 2014 | 12:59 AM
My car has the the same problem but only when I make hard right turns or sharp right downhill turns. I checked the brake shield searched for rub points I have no liners so thats not the problem and the only thing that needs replacing that side is the comp rod but that cant be it... so I leaning toward the hub bearing and aftermarket ones are relatively cheap oem I believe only comes as the whole knuckle assembly. Only one way to see if thats the problem haha
Reply 0
