Rear corner sitting lower than other corners of car
Old Feb 2, 2015 | 03:25 PM
JoolR's Avatar
Hi everyone, I have a 2007 G35 coupe with 100k miles that has a bit of a suspension issue. The rear passenger corner of the car is sitting about 3/4's of an inch lower than the rear driver side. The car has been completely factory stock, so I figured I'd swap out the rear struts in case they were the culprit but there was no change in the ride height.
I did lots of searching on the forum and unfortunately most of the information I found regarding uneven ride height was related to lowering springs, not stock suspensions. Some of the posts suggested swapping the springs side to side - I did try that but the ride height has remained unchanged.
I've taken a look at the various rear suspension bits but it doesn't look like anything is bent or out of place. Are there specific bushings or arms that I should more closely inspect for damage? I would think that something damaged enough to cause a 3/4 inch drop would be obvious, but I haven't been able to pinpoint the cause so far. Any suggestions or advice would be greatly appreciated, thank you!
Old Feb 5, 2015 | 10:24 PM
digital sol's Avatar
Mine is like this as well but only for the front right corner but I am on springs. I contribute mine to torn bushings but i wont know for sure until I finish swapping them. In for info though!
rezendvous420
May 31, 2020 01:26 PM
mbe093
Lights
Oct 2, 2016 11:09 PM
w4kj4k
Engine - Intake/Fuel
Oct 7, 2015 01:26 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
ResoG35Sedan
Jul 14, 2015 10:30 AM
