Has anyone seen these new front upper arms?
Aug 20, 2015 | 11:36 PM
Check these out, they look pretty sick
Anyone here ever run or hear of Voodoo13?
http://voodoo13usa.com/shop/350z-z33...50z-g35-coupe/
Reply 0
Aug 21, 2015 | 12:52 AM
Yes... Voodoo is well known in the 240 community. They make some quality stuff. More for drifters but still look super solid...
Reply 0
Aug 21, 2015 | 07:46 AM
Looks great!
Reply 0
Aug 24, 2015 | 09:29 PM
the middle area looks like a great spot for dirt, water, and **** to collect into
Reply 0
Aug 24, 2015 | 11:27 PM
Quote: the middle area looks like a great spot for dirt, water, and **** to collect into
You rally your car? Ha ha, J/K. I can see stuff maybe building up over the years little by little, but unless if you are mudding around, a decent quick wipe once a year (or even oil change) should keep it pretty clear of debris I'd assume. It is pretty high up in the fender well.
Reply 0
Aug 24, 2015 | 11:46 PM
Oh, man. That may be the best design for adjustment I've ever seen. I like those a lot.
Reply 0
Aug 30, 2015 | 05:35 PM
My only complaint would be they don't seem to offer any caster adjustment and I hear they are really expensive. I'll stick with my SPL's.
Reply 0
Aug 30, 2015 | 07:20 PM
To adjust caster all you'd have to do is adjust one of the rear adjusters in or out without adjusting the other side. The price is on the website at $699, which is decently cheaper than SPL if I remember correctly, lol.
Reply 0
Aug 30, 2015 | 07:57 PM
SPL is 759 list but i am sure you can get it cheaper from some company or another running a special. but otherwise they look good almost like the spl but a solid triangle.
Reply 0
Aug 30, 2015 | 10:51 PM
Z1 just came out with the most affordable, quality, best bang for the buck set IMO.
https://www.z1motorsports.com/suspen...ms-p-8533.html
Reply 0
Aug 30, 2015 | 11:26 PM
Quote: My only complaint would be they don't seem to offer any caster adjustment and I hear they are really expensive. I'll stick with my SPL's.
Caster adjustment should never be necessary. If your caster is off, you have bad suspension parts somewhere or a tweaked frame.
Reply 0
Aug 31, 2015 | 01:24 AM
Quote: Z1 just came out with the most affordable, quality, best bang for the buck set IMO.
You have to unbolt those just to do any adjustment. That's pretty lame.
Reply 0
Aug 31, 2015 | 03:17 AM
Quote: You have to unbolt those just to do any adjustment. That's pretty lame.
Oh god. Do you unscrew the bushings to adjust? Hell no. If you're gonna adjust anything that way it's gotta be the balljoint like the kinetix.
Reply 0
Aug 31, 2015 | 10:54 AM
Looks like you can just pop the one ball joint off and adjust it but doing that will un-settle the suspension. C'mon Z1. Didn't even expect that. Honestly, for the price, I'm still going to buy them lol. I don't change ride heights ever.
Reply 0
Aug 31, 2015 | 11:10 AM
Quote: Oh god. Do you unscrew the bushings to adjust? Hell no. If you're gonna adjust anything that way it's gotta be the balljoint like the kinetix.
I've installed the Kinetix ones before, and I hated having to unbolt the ball joint a bunch of times just to adjust the camber to what I needed. Such a PITA.
Reply 0
